Very much so. Trying to make what I can out of solid wood instead of using the plywood. Just using the plywood as a template.Nice attention to small details, makes the ship look great.
Thank you. Only bad thing is I cant do like I normally do with them because the opening is so small I cant put the deadeyes through there. I have to tie the deadeyes off in place.Shrouds are looking good!
I never even thought of that as an option (pre-rigging the deadeyes). That would take some careful measuring to keep things level but it sure would be easier.Thank you. Only bad thing is I cant do like I normally do with them because the opening is so small I cant put the deadeyes through there. I have to tie the deadeyes off in place.
Yes it does. Normally I'll tie them off with them in that little jig I made and then pull them out so I can seize the lines but having to do that with them in place is more of a pain in the buttI never even thought of that as an option (pre-rigging the deadeyes). That would take some careful measuring to keep things level but it sure would be easier.
Thank you. Normally I'll use a 1x5 piece of srap wood but for this one I'm doing it all by eye.Ratlining is quite a chore. You do very precise work, Gibby_74. The rich color makes this model really stand out.![]()
Good morning Derek. Your Golden Hind is looking great. I’m always amazed at how wonderfully you work and progress so quickly- talent. Those nails stand out and for such a small thing add a lot of value to your model. Cheers GrantFinished making the main mast lower section. And mounted the crows nest in place. The bracing for the crows nest I decided to add some wire for nails. I think I use that in future builds. View attachment 295541View attachment 295542View attachment 295543View attachment 295544
Thank you. That really means alot. I always try to improve upon what I have learned from previous builds. And like this one I tried to make as much as I could out of solid wood and trying different thing like the brass nails. And I'll definitely be getting more of these blocks from dry dock that's for sure. They are absolutely amazing and have taken this build to the next level.Good morning Derek. Your Golden Hind is looking great. I’m always amazed at how wonderfully you work and progress so quickly- talent. Those nails stand out and for such a small thing add a lot of value to your model. Cheers Grant
