    **VIEW RULES HERE**
Hello Dear Friends
Finally !!! Yesterday I mentioned that the new shipyard has opened with baby steps, but today it really opened to full effect.
Next on the agenda was the construction of the front canopy or “bovennet” in Dutch (part circled in green on the picture below.) And – let me tell you right from the outset – I knew this was going to a challenge for reasons I will mention later.
Photograph: Piet Sanders
The kit-provided parts for this section comprise of the two side frames (black arrows) , the uprights that will fit underneath the roof beams at the front and rear for support (green arrow) and the roof beams themselves (red). The shortest roof beam (indicated by the two psychedelic green lines) is obviously the one that goes right at the front.
The two green laser-scribed marks indicate the correct height of the side frames. In other words, those two marks are supposed to be flush with the top of the bulwarks. That necessitated removing material from the bottom of the frames. The red line indicates where I have already removed the required amount, while the black lines indicate the portions that need to be removed on the rest of the frames. The two black dots also serve a very important purpose. The idea is to pre-break, pre-cut, pre-saw (whichever your preferred method of operation) the frame at those two points to allow it to follow the curvature of the hull. I used my little saw to saw halfway through the triplex.
After I had pre-sawn the frames, I could easily bend them into their required positions.
NOW FOR THE CHALLENGE!
Men and mice who have built the Willem Barentsz, have mentioned that with the side frames in their designated places, the front roof beam is too short and does not reach both side frames simultaneously. In other words, if it fits into its designated notch on one side, it doesn’t reach the other.
The reasons are obvious – either the kit-provided roof beam is too short or my predecessors have all built the ship too wide at that point. With that in mind, I have consciously tried to build as “narrow” a WB as I could. However, after carefully measuring out the position of the two side railings (using both the plan and gun port No 5 as reference), I experienced the exact same problem. Luckily for me, I had @pietsan Piet’s brilliant log to follow. His solution: add another layer of inside planking to both sides of the bulwarks at that point and if that is not enough, move the railings further forward to the bow to gain those final fractions.
Now if you know Piet Sanders like I have come to know him through his builds, this is one man you do not second guess - never!. I immediately added two 1.5mm x 6mm walnut planks (on top of each other) as interior planking to both sides of the bulwarks which moved the frames 3mm closer to each other. That did the trick and did not require me to move my railings forward – and strictly speaking - out of position. After the inner planking had been added, a dry-fit showed the front roof beam to fit perfectly.
The photograph which I posted last night (below) shows the first of the inner planks being glued into position.
When that was done, I could now glue the frames to the inside of the bulwarks.
Starboard frame glued into position (exterior view).
Port Side frame glued into position (exterior view).
In addition to the outer planking that will cover the frameworks, I have followed Piet's example and have also opted also to add a further layer of inner planking. The result is that when this is finished nothing will be visible of the frameworks.
Inner planking in progress on the starboard side - viewed from the port side.
And this is what it looks like from the outside. Obviously, the whole area in green will be covered by the exterior planking in a shape roughly equal to that of the green outline. The red arrows indicate the pre-sawn parts that facilitated the easy bending of the frameworks.
And after all this paraphernalia was completed, I now had a front roof beam that fits perfectly into its two notches and two frames in their correct positions. Now it's just a case of slowly finishing off the whole assembly - time consuming, but hopefully, pretty much routine.
And that is all for tonight dear friends. Enjoy your time in your shipyards and hopefully I can soon post a next update!
Wow, another great “How to do it” Tutorial. I’m weeks away from that part of the build. I spend a lot of time reading and rereading WB logs.
I think there must be a world shortage of Balsa, my order is going on almost six weeks.
I'm glad you find it helpful Jan. Multiple logs can also be confusing at times - that is why I have chosen Pet's one to follow and it is paying great dividends.
Kudos on getting your shipyard up and running. I’m following with interest. Unfortunately my shipyard is shut down indefinitely due to the Admiral's condition. In lieu of building I have started reading The great Boer war. Quite interesting.
My friend that is not good news. I am thinking of and praying for you both that things will get better. Are you reading the Pakenham version? The Boer War is a fascinating piece of history and one that was very deeply embedded in SA history for a long time afterwards. When my one great grandmother heard that I was going to study English, she broke all ties with me.
Frequently and randomly emails, intend to notify me of SOS build updates, don't find my inbox for whatever reason...
Having written that, this build will undoubtedly bring forth a WB/WS model of note, including historical context and very useful addendum to the build instructions. Thumbs-Up
Johan I have the same problem - for instance, I do not get any notifications on any of the Bluenose builds. When I check what is happening on the forum, I manually go to all the logs that I follow. Thank you for the very kind words - I am trying my best to put together something that I am happy with!:)
Hello Dear Friends
Good morning Heinrich- so good to see your shipyard open again. Excellent post and fantastic work. Cheers Grant
Aaahh Grant, thank you for the welcome. It is great to be fiddling again - an interesting challenge trying to remember where I put everything. I spend more time searching around for things than working! :)
That has nothing to do with your new shipyard; it's something I experience every morning...ROTF
Oops! No, Johan, I'm still good in that regard - it's just that some of the boxes have been packed a long time ago and with the move, there are many boxes! :eek: So, it's a bit like unpacking a surprise packet each time!
:-) in fact: no and no.
When placing the bulwarks they should be facing a little bit inwards to match the width of the first beam. In a future update of the building instructions I will make an extra note on that. You have solved it in a proper way, like a real Dutch shipbuilder. And it isn’t wrong, as there were no fixed rules on this. Only - when placing the shrouds these should not touch the bulwarks. If this happens just add a small beam as channel before mounting the deadeyes.
Hans
:) in fact: no and no.
Hans
Thank you for the reply Hans - whether I have found a complete solution, I don't know yet - maybe there will be other bugbears (like the potential issue with the shrouds) that will crop up later.
For the sake of my fellow modelers and prospective Willem Barentsz builders, maybe I should just explain the build up of the front canopy a little more and/or better.
Hans was concerned that on this picture that I posted last night the frames look as if they are sloping "outwards" and that that may well be the reason why the front roof beam seemed to short at the front. This photo is indeed misleading as it really does like the frames are leaning outwards. In fact, they are perpendicular to the deck - done to obtain the maximum gluing surface between the side frames and the insides of the bulwarks.
Looking at Piet's build, it is clear that the side walls of the front canopy are also perpendicular to the deck and are neither leaning neither inwards, nor outwards. As mentioned last night, it was through @pietsan that I became aware of the issue because his front roof beam was also too short. Therefore I was anticipating it and followed Piet's example.
To bring the two frames closer to each other, Piet applied a layer of inner planking between the existing bulwarks and the frames. Unfortunately, Piet did not take pictures of that process, but the picture below gives us a clue.
If you look at the section that I marked "Outer Planking" you will see that it is directly against the frames, but still sits well inside the top railing and not on top of it as the instructions suggest. This is because they are seated on top of the unseen inner planking. What I have marked as inner planking in the picture above, is simply planking applied to the inside of the frames and has no bearing on how close the two frames are to each other.
Once this phase has been completed, the finishing layer of planks can then be applied on top of the outer planking. That layer of planks will be shaped and will sit on top of the top railing as per the instructions. In fact, you will see that it almost lies flush with the outer edge of the railing.
Figuring this out is the result of long hours of studying trying to figure out Piet's build. :)
I hope that this explains the process better and more in detail. In the meantime, I am still planking away merrily and will post updates when done.
Oh that looks like a beautiful setup you have there . Sorry I'm an IT guy and need to setup my house as well as I setup my office
Thank you Rob. It's actually quite funny - I asked for a table/desk that I can use in the shipyard to build on, but got sent this instead. Seeing that this was courtesy of the landlord, I am not complaining though. Saves me from preparing my classes at the dining room table. :)
Great to see that the new shipyard has opened Heinrich, my friend.
I also found your excellent bookreview from the book of Willem Barents, i have also been reading a bit in the book, and i love it. You nailed it with your review
By the way, i love the coins of the Blue Nose
