Nah, they didn’t last long enough for me to use them.I’m just wondering if the hot dogs helped locate the cannons?![]()
Good morning Vic. Hope you are al good. Eish now you make me worried. I just glued mine on directly without any pins. Good idea tho. Cheers GrantI’ve put together the posts and railing for the foremast belaying pins. I hope the metal pins in the bottoms of the posts will help secure them to the deck. View attachment 298370
You just need a taller belfry!The bell is a bit big. View attachment 298486
Or a tall(er)ship...You just need a taller belfry!![]()
Hi ,Vic your model is coming on nicely, that's the same bell that was supplied with my Black Pearl it didn't fit so I had to cut it down.The bell is a bit big. View attachment 298486
Is that sauer kraut on the hot dog??
I've got bats in the belfry already!You just need a taller belfry!![]()
That's exactly what I did, Tony. I think I saw that somewhere else. Maybe it was your build?Hi ,Vic your model is coming on nicely, that's the same bell that was supplied with my Black Pearl it didn't fit so I had to cut it down.
mine is in the opposite directionAnyone know what this post/bit is for and if it’s facing the correct direction? I assume it’s supposed to have a pulley inside the square hole, but I’m not sure of its use or facing. The directions have a picture of one, but it has no hole. View attachment 298598
Thanks, Gilbert. I took it off, put a pulley in it, and stuck in back on.mine is in the opposite direction![]()
Good morning Vic- that make at least 2 of us. My thoughts exactly. I enjoy watching you build here- great job on the bell BTW. Cheers GrantSome of you may wonder why I go into so much detail. I know many of you are much more experienced and knowledgeable than I. You may see something I could do better. Others may be as green as I. (I’m a permanewb.) Maybe they can learn something from my mistakes. Who knows? I just know I’m enjoying it. Thanks for watching.
