Le Soleil Royal ZHL Build Log [COMPLETED BUILD]
I’ve put together the posts and railing for the foremast belaying pins. I hope the metal pins in the bottoms of the posts will help secure them to the deck. View attachment 298370
Good morning Vic. Hope you are al good. Eish now you make me worried. I just glued mine on directly without any pins. Good idea tho. Cheers Grant
Anyone know what this post/bit is for and if it’s facing the correct direction? I assume it’s supposed to have a pulley inside the square hole, but I’m not sure of its use or facing. The directions have a picture of one, but it has no hole. image.jpg
Some of you may wonder why I go into so much detail. I know many of you are much more experienced and knowledgeable than I. You may see something I could do better. Others may be as green as I. (I’m a permanewb.) Maybe they can learn something from my mistakes. Who knows? I just know I’m enjoying it. Thanks for watching.
I'll tell you before it's too late. There should be three pulleys in this biteng. Here passes the turnbuckle of the main-yard halyard, fore-yard. On the very halyard of the yards, a large three-piece block is involved. Due to the fact that the yards of the foremast and mainmast are heavy, they are wrapped through three-pin blocks. Isn't that in the instructions?
Good morning Vic- that make at least 2 of us. My thoughts exactly. I enjoy watching you build here- great job on the bell BTW. Cheers Grant
