Thank you. I was wondering what you methods are....Thank you very much for your feedback.
Yes, these stressed joints are soldered with silver paste. It is ideal to be black as well as stain-free brass.
Soldering is a fear at first, but when the system is touched so that the material doesn't burn, it just joins, it's very nice. I recommend, I solder only with cheap Kemper pencil solder and ok.![]()
Thank you, Paul. Easy to rotate. A suitable box is placed around the model and firmly glued with paper tape. Then there is no danger of turning.Brilliant! Installing the rudder with the ship upside down! If only I would have conceived of your hanging mechanism...
Hallo Ondras alias @Ondras71My previous kit construction has been completed.
[URL unfurl = "true"] https://modelshipworld.com/topic/14770-hms-president-by-ondras71-finished-sergal-modified/ [/ URL]
Another construction I started in 2017 is a build from scratch. I've decided for a 16th century galleon, which I always liked, specifically the 1597 Roter Lowe..
I've had the 1:60 plan at home for many years, it's a copy of a well-known German plan..
For the construction I use light and dark cherry wood, maple wood, brass..
Ondras.![]()
Happy birthday OndrasThank you very much friends for more than family greetings !!![]()
Of course I celebrate with the model ..
Thank you so much Herman. I'm looking for everything I need on the forums and I'm happy to find some instructions. Therefore, I will also be happy to connect any aids. I like your construction very much, I devour all Dutch ships ...Happy birthday Ondras
I've recently joined the forum and have just leafed through your build log. Very inspiring and educational.
