Roter Löwe 1597 by Ondras71 - scala 1/60
Yes it looks very elegant. I did it on my Spanish Galleon but the proportions where not okay. Yours is perfect.
Very fine and as usual very accurate work - I like the view on the balcony with rudder - very good work
Thank you all very much for the feedback, friends.:)Thumbsup I thank everyone for the like..Okay
I want to finish the rudder before placing the model on the final stand.
After a longer time of soldering hinges ..
Ready for cleaning and blackening..
I found that cleaning with nitric acid must be done carefully, 0.2 mm sheet metal and tubes with a wall of 0.1 mm are terribly tricky, especially the tubes can be quickly etched by acid .. I had to replace one.. :eek:
Thank you very much friends !! I thank everyone for the like.. :)
So in the end, the rudder hinges, which I made from a weak material, were damaged by the acid so that they could not be used, they softened completely.. o_O I made new 0.3 mm thick sheet metal and 1.3 / 0.2 tubes..
Extra work, but in the end the hinges are 100% better than the first.. Explosion
Rudder hinges placed..
Are the hinge pins soldered to their strapping? Or glued? Beautiful work by the way!
Thank you very much for your feedback. :)
Yes, these stressed joints are soldered with silver paste. It is ideal to be black as well as stain-free brass.
Soldering is a fear at first, but when the system is touched so that the material doesn't burn, it just joins, it's very nice. I recommend, I solder only with cheap Kemper pencil solder and ok. Thumbsup
