     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
Are the hinge pins soldered to their strapping? Or glued? Beautiful work by the way!Thank you very much friends !! I thank everyone for the like..
So in the end, the rudder hinges, which I made from a weak material, were damaged by the acid so that they could not be used, they softened completely..I made new 0.3 mm thick sheet metal and 1.3 / 0.2 tubes..
Extra work, but in the end the hinges are 100% better than the first..
Rudder hinges placed..
Yes, these stressed joints are soldered with silver paste. It is ideal to be black as well as stain-free brass.the hinge pins soldered to their strapping? Or glued? Beautiful work by the way!
