     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
will come back. if you have an E.MAIL it will b nice-as it is more private - mine is -peandersen@telefonica.net.Hello I have worked through your log and am very curious in any progress you have done if at all? I will be starting my own Montanes so will be referencing your build and hoping you will be continuing at some point
Problem solved and bowsprit came to shape.
I used brass black solution for brass strips ans simply glue them to their places. I glued all three parts together and tie down with 0.5mm brown thread.
Hi RobHope everything is well with you @Bilal ZEYBEKOĞLU are you guys still on lock down with no chance of getting to the shop? Or has the montañes been put to the side for now?
I am glad to see everything is going well!! I don't plan on catching up to you soon but you log is one I'll be using to make sure I build my Montanes up to the right standards. Hopefully we will see you on her soon and if not is fine too just glad you are doing wellHi Rob
Thanks for asking. Up to now everything is ok.
First Corona and then job change caused to put Montanes to the side. But soon I'll begin and finish the model.
I wrote in detail below :
Sirena-58, Scale : 1/40, LOA : 46 cm, POB by Bilal
All the drawings required for the construction of the model were drawn by me according to the ship's 3d file. Building time is 30 days including drawing.shipsofscale.com
Best Regards from Turkey.
Bilal.
