This side is planked! It was a hull lot of work!
I started painting the white below the water line. This way I can see if I need to do more sanding. I brushed on the paint because I want to still be able to see the individual planks. Anyway, more sanding and painting. Then to the other side. Once both are finished, I will add the lower wales, and paint the black above the water line to the bottom of the lower wale. Then I can clear coat both the white and black with a satin clear.
A few pics of current progress…
