I'm curious of how the bowsprit fits into the hull. (That's because of filling in the balsa cut out before planking)
**VIEW THREAD HERE** |
Jan, to start off with, remember the bowsprit is anchored into this notch at the front of the ship.I'm curious of how the bowsprit fits into the hull. (That's because of filling in the balsa cut out before planking)
Good morning Heinrich- Eish!! ....and I thought only I did those sort of things. Funny how those “relaxing” moments with this hobby always rise up and bite us on the ..... Cheers GrantHello Dear Friends
Just in case you think everything is always plain sailing in my shipyard, let me share this with you. I felt like doing something relaxing tonight and thought that the mast top for the foremast would just be the number. I carefully cut out the laser-cut parts from their sheeting and started assembling. A little bit too much pressure on the floor part to get it to fit snugly into the notches of the uprights and
Those who know me well enough, will know that those parts are going straight into the dustbin.
Good morning Ron- yep you owe me a whole lot.I had better get the mint busy making more![]()
Nope ... not only you! I also manage quite well, thank you! No finesse man, I tell you ... no finesseGood morning Heinrich- Eish!! ....and I thought only I did those sort of things. Funny how those “relaxing” moments with this hobby always rise up and bite us on the ..... Cheers Grant
Heinrich my friend, since you are teaching English , i reakon that you also studied the history of England , and then this might be of interest to you,
Wrak zeventiende-eeuws beroemd koninklijk oorlogsschip gevonden voor Britse kust
HMS Gloucester: Volgens wetenschappers is de vondst van het oorlogsschip de Gloucester in de Noordzee mogelijk „de grootste maritiem-historische ontdekking sinds de vondst van de Mary Rose”.www.nrc.nl
This is a link to NRC handelsblad, describing the findings of a British warship of the 17th century, called the Gloucester
i hope that you enjoy the article.
I was off the yard for some days ....... a lot to read in several build-log ......... and now I see a bowsprit on your WB! It looks nice, Heinrich. Where have I seen installing a bowsprit also ......All dry-fit, of course, but the crosstrees have been checked for fitment, and the bowsprit has also been tapered - from 5.5mm where it goes into the deck fitting to 4mm at the end. Now it has to receive its clamps and "scheerhout" at the front end.
Welcome back Peter and thank you for the kind words. Yes, I have made some progress on the actual build, even though the biggest progress was in the research and "development" department. Soon you will see a second WB being built alongside this oneI was off the yard for some days ....... a lot to read in several build-log ......... and now I see a bowsprit on your WB! It looks nice, Heinrich. Where have I seen installing a bowsprit also ......Now your WB get lines in more directions and they are looking fine!
Welcome back Peter and thank you for the kind words. Yes, I have made some progress on the actual build, even though the biggest progress was in the research and "development" department. Soon you will see a second WB being built.I was off the yard for some days ....... a lot to read in several build-log ......... and now I see a bowsprit on your WB! It looks nice, Heinrich. Where have I seen installing a bowsprit also ......Now your WB get lines in more directions and they are looking fine!
Thank you very much Stephan. You are 100% correct in the scheerhout is for the crowsfeet!Looks real good Heinrich. Like the bowsprit and that you make a plank to attached the crowfeet.
Thank you very much Peter - much appreciated!Beautifull work on your masts Heinrich![]()
Thank you very much Johan. Here is a sobering thought though. Once the masts go in permanently, there is a very good chance she is not leaving China.A lovely little beauty.
