Not only that but they come in nice little plastic boxes you can use to store misc. small parts. At last count I had 125 of these. Oh yes, I spent lots of $$ on my RC hobby.Excellent engineering to fit that servo. I can commend you on those HiTec servos - they are the bees knees!
Thank you to Heinrich and rtibbs,
The photo is a bit misleading that Hitec servo is the rudder servo, so I need to confess the sail winch is not a Hitec but a low cost Bangood unit which will hopefully last more than a few runs.
Cheers,
Stephen.
Thank you for your comments John,Fantastic work Steve, you are a very accomplished model maker, on the engineering and the woodworking side, your LT100 is packed from stem to stern, I'm looking forward to seeing more,
Best regards John,
Hello Stevedownunder, could you tell me the real dimensions of this boat? Thanks, great job. CongratulationsThanks Jim.
Cheers,
Stephen.
You made a great job with this planking, Stephen. And remaking planks is part of the job.At Last Deck Planking is Done (well nearly).
Decisions were made, for better or worse on the center planks forward and aft, now that it is done I wonder why I was so worried about how it was going to look with my interpretation of Teds description, that’s not to say others will think that it is not okay, but at the end of the day this is my interpretation, right or wrong.
Making the forward and aft center planks was a very time consuming job.
Starting with some old school tracing paper to make a template. The paper was taped down to make sure it was flat then I used a sharp scalpel to cut the outline and wind up with a shape that is pretty close to being right.
Once cut out the template was stuck down on the board using a glue stick, then traced around with a pencil this ensured the plank would be bigger than needed (easier to remove material than put it on) then roughly cut out with a scroll saw.
Next came the slow part of carefully trimming down to fit inside the required space without gaps, then removing the required amount for caulking would be easier or at least that’s what I thought, didn’t quite work out that way on the first one, as I removed too much material, winding up with too much clearance I had a look at trying to save the plank by moving it forward to close the gap but in the end there was nothing I could do except make another one. Apart from the wasted time the most upsetting part was the waste of material.
View attachment 313373View attachment 313374
Lovely fit with no clearance at this point.
Then disaster too much clearance, even moving it further forward didn't work, the gap was too big.
View attachment 313372View attachment 313375
Once the fore and aft center planks were done I pinned them in place temporally before removing them to enable gluing in place, when gluing I only caulked on one side to ovoid getting my glue and paint mix everywhere.
View attachment 313377View attachment 313378
Once glued and half caulked I pushed glue mix into the remaining gap.
Each of the other center planks needed to be custom made either slightly wider or with a slight taper, these were quite quick to make and install.
View attachment 313379View attachment 313380View attachment 313381View attachment 313382View attachment 313383View attachment 313384
Unfortunately gluing the aft cabin skylight in place before planking turned out to be a bad idea, I managed to damage the paint work several times with the drill chuck, you would have thought I would have learnt my lesson the first time, when the drill chuck hit the paint.
There is some cleaning up to do and I have been reducing the severity of some of the weathering to give a more unified look, this is more because when looking at the model I couldn’t help but think I had gone a bit far and it just looked poorly made.
Next time I start on Coal hatches.
Thanks for looking in and reading my ramblings or just looking at the photo’s and stay safe.
Cheers,
Stephen.
Thank you Heinrich,Dear Stephen. I always sit and wait with bated breath on your next update. First off - that center plank is absolutely superb work - even though I share the pain of taking away too much material in order to get it perfect!Ouch! The second attempt though is masterful. However, there is something else that I want to throw out at you. When the weathering of the deck is viewed in isolation, I can only stand in awe of what you have achieved, but this is where my question lies. Your deck structures are absolutely pristine and look as if they have just been installed on the ship without having been exposed to wind or weather for even a single day. To me the contrast between the brightly colored and brand-new looking deck features and the weathered deck is just too great. I hope you don't shoot the messenger!
Thank you Daniel,I found a nice video
Kind regards,Daniel
Thank you Peter,You made a great job with this planking, Stephen. And remaking planks is part of the job.
I am so glad that you took my comments in the way that it was intended. Weathering of that deck was a massive undertaking which you have pulled off in exemplary style. And if you plan on weathering the deck structures too to give uniformity to the ship then "Bob's your uncle", all is good and I am a happy camper!Thank you Heinrich,
Yes I was kicking myself when I stuffed up the first one, it was time to go inside at that point and try again the next day.
I am glad you have bought this up and yes there is a disparity between the deck structures and deck at the moment however I will be weathering the whole boat in due coarse. My thinking is that I want to weather all structures at the same time so to speak, once they are built to give continuity, but the deck is something I didn't think I could weather after installing.
I am also a great believer that weathering should not be used to hide sub standard work, in my opinion it doesn't work, you need a well made item before weathering to achieve the best resalts.
I whole heartedly welcome constructive criticism so thank you again.
Cheers,
Stephen.
Just between me and you Heinrich, I don't have much experience in weathering and will be approaching it in a cautious manner, a little bit at a time.I am so glad that you took my comments in the way that it was intended. Weathering of that deck was a massive undertaking which you have pulled off in exemplary style. And if you plan on weathering the deck structures too to give uniformity to the ship then "Bob's your uncle", all is good and I am a happy camper!![]()
