Thanks Will, I tried variations of the red and settled for a colour very close to the Model Expo red. Busy painting the black cap rails at the moment, multiple coats.
Instructions on how to paint wood that nicely please Roger...
Thanks Paul, by the way I hope you are beating that covid crap and on the mend. Take care.You should be happy with the result! Thin paints, multiple coats, lots of sanding. Check. And varnish the substrate if it has looser grain prior to painting. Expertly done my friend!
The results from all the work are what will show through times. But I must mentioned that the caprails being basswood will be soft and easily damaged as work continues. Excellent paint workThat is a compliment in itself coming from the Vasa artist
For the ass end I used alaskan yellow cedar, which gave me an initial smooth relatively non-porous surface. I then used Vallejo Model Air thinned in a 1:10 ratio with Vallejo thinners. Those aft planks were airbushed before fitting then sanded down with fine 600 paper, then 1500b between coats. After that I hand brushed on multiple coats of the same Vallejo Model Air red. The Model Air is already thinned suitable for airbrushing and tends to settle evenly. Even so I watered the paint down a little more to give me a very thin even coat each time I brushed. As long as I did not go back over the brush strokes it tended to even out. In all there are probably six coats but I can see little areas that may need a little more work.
The black cap on the stern is basswood. So I firstly gave the wood a "seal" of two coats of Vallejo Matt Acrylic Varnish, thinned a little too. Then two coats of Vallejo black primer followed by two coats of Model Color (Colour) black followed by, you guessed it, two coats of the varnish again. The Model Color range is thicker paint so I still thin with a little water. I think I am still at the experimental painting stage but so far I am happy with the results.
I’ve already found multiple disadvantages of that soft basswood but it does have it’s uses. I’m keeping very fine filler, black paint and the varnish handy, just in caseThe results from all the work are what will show through times. But I must mentioned that the caprails being basswood will be soft and easily damaged as work continues. Excellent paint work
Alaskan yellow cedar is a wonderful wood in place of boxwood. AYC finishes beautifully with just wipe on poly makes a smooth velvety surface and much easier to use than basswood.I’ve already found multiple disadvantages of that soft basswood but it does have it’s uses. I’m keeping very fine filler, black paint and the varnish handy, just in case.
I changed out the inner bulwark timbers to yellow cedar and I have Swiss pear billets to cut for the decking and other parts of the build.
Thanks for your input, comments and support.
Right. Heinrich will not leave his neighborhood until he sees your next successful post. Wait, nevermind, he has to do that regardless...Oh boy, nothing like a little pressure![]()
My first time working with the Alaskan yellow cedar (AYC) but I like it, a lot. I didn’t order enough but for this build I’m going to continue with the mix of basswood, Swiss pear and the AYC where appropriate.Alaskan yellow cedar is a wonderful wood in place of boxwood. AYC finishes beautifully with just wipe on poly makes a smooth velvety surface and much easier to use than basswood.
Right. Heinrich will not leave his neighborhood until he sees your next successful post. Wait, nevermind, he has to do that regardless...![]()
Hallo @RogerDView attachment 240358
I started building the Model Shipways Syren last year. I knew, because of other commitments, it would be very slow progress for me. Since joining SOS I have read through many logs, threads and posts. The knowledge of members, incredible model builds and workmanship on this site make it kind of humbling to even think I should start a log. However, I need to force myself to keep going and complete the Syren. So a log it is.
My first few photos are progress so far. I am currently working away at the hull planking. Even though the hull below the waterline will be plated I am thinking of trying my best to complete the planking as though it were going to be visible. Extra work no doubt but that way I can try my hand at proper planking techniques. It will be a good learning experience for me. Then I get to cover it up with copper plates!
I did not simulate caulking of the plank seams above the wales. I was going to eventually paint the sides dull yellow ochre. Changed my mind because I thought the fibrous basswood would look terrible. Then after doing those upper areas, decided I would stain instead, then realized I should have after all used a pencil for caulking. So now I am hoping a Golden Oak stain will darken the seams and make it appear as though they are caulked. Time to experiment I think.
So a few photos to start me off.
View attachment 240366View attachment 240364View attachment 240365View attachment 240363View attachment 240362
