Yes, I am too, thanks for providing me the link a few posts back. Now I have the tape in hand I am happy with the more realistic look of the plates and nails. It will make a huge difference.I am glad you went this route Roger. About the weathering - I wouldn't but that's just me!![]()
Found your log on Syren and will follow.I just finished the standing rigging and am now starting the yard construction and rigging. Been working of this since Christmas 2020 when my daughter gave the kit to me.
As to the copper plates I made a jig for the 3 patterns and using a small press was able to quickly make the plates.
View attachment 311277View attachment 311279View attachment 311280
all the time. Even when I am finished I still wonder if it's good enough to display.Do you ever get those times when you complete part of your build and then think it just isn’t good enough? I had completed the cap rails on my model and then added some 1/16” x 1/32” shaped trim work. It was glued on with PVA, thank goodness. That was yesterday.
Today is “Isopropyl Sunday”.
I know what you mean. I find as I progress, learn and research the work I did even a few weeks or months ago could have been way better. As experience grows it means my progress slows. The problem then is how many redo’s make sense? Maybe finish the present project as is and move on to the next using everything learned so far. As I try to increase my knowledge from centuries ago, trying to be accurate, I spend more time reading than building. I have to admit though, this hobby for me is as much about the model as it is about the knowledge of the Age of Sail.all the time. Even when I am finished I still wonder if it's good enough to display.
No doubt- I spent most of my time cutting off rigging I did not do correctly yesterday- I shared your Isopropyl SundayDo you ever get those times when you complete part of your build and then think it just isn’t good enough? I had completed the cap rails on my model and then added some 1/16” x 1/32” shaped trim work. It was glued on with PVA, thank goodness. That was yesterday.
Roger I'll jump in on the copper aging dilemma. I did not protect mine and after 21 months the finish has dulled to a pleasant patina and no green tint.
Here's a picture taken just now showing the after section of the port side. Hope the picture helps.
And reading you log I've decided to start a Syren log of my build from today forward.
No doubt- I spent most of my time cutting off rigging I did not do correctly yesterday- I shared your Isopropyl Sunday![]()
Roger the red really makes your woodwork jump out. The whole thing comes together with the black cap rails. Can’t wait to see. Great job what else can be saidA little while ago I decided to jump ahead a little and complete the opening for the rudder. The hole (helm port) has to be large enough to allow the rudder to swing freely. It looked straight forward enough until I realized how critical it was to align the hole inboard with the angle created by the stern post. You have to drill from inboard and outboard, increase the hole gradually from both sides and hope they meet. This is one of those one shot mini-projects. Yikes!
The trick is to get that outboard hole drilled close in to the stern post using a very fine bit. Then gradually opening it with larger bits, needle files and a really sharp exacto blade. To get a marker on the inboard counter I drilled very carefully upwards through the hole from below. The tiny hole in the counter then gave me a rough guide as I enlarged the counter hole downwards. A small but important detail that I think turned out ok and it is large enough for the rudder to turn.
As I looked at the opening I thought about the amount of sea water that would be forced upwards when the ship was working in heavy seas. It just didn’t make sense to me that it was not covered in some way while still allowing the rudder to work. Modern day vessels have a watertight arrangement in the steering flat where the integrity of the hull is penetrated. I was convinced there must have been at least a rudimentary stuffing box type of arrangement on those sailing ships.
It turns out that the crew used greased cloth (apron) and other types of materials packed around the rudder “head” to limit water ingress. On the Victory, for example, a rudder coat of tarred canvas was used. In 1779 and beyond a new design allowed for a smaller hole that reduced the water intake but the canvas apron was still used. A little detail I might add to my model later on.
