Thank you Uwe, I really appreciate the wishes and it’s a good time to thank you for all you do for this excellent forum.
Awesome Roger! Hope you have a great day celebrating with family and friends!
I do not know how I missed that posting on Wednesday. Apologies Roger. Your Syren looks exquisite with the red beautifully offsetting the black wales while the rest of the woodwork is just superb! When that deck is planked - and I know that you will create a stunning deck - that whole ship is going just going to "pop"! And then not even to talk about the black and red deck ancillaries.
And then of course: Happy Birthday my friend! May you be granted a year full of health that you can enjoy with your loved ones and treat us on beautiful model building!
Happy BDay Roger!
Happy Birthday, Roger!![]()
She's looking lovely Roger. But remember that when using softer woods it isn't necessary to simulate chaulking as the stain will darken the joints as the soft wood absorbs the stain. AYC is harder than basswood but still absorbs the stain. On my model Cheerful I didn't add caulking and the blow photo shows the seams with only one coat of wipe-on-poly on AYC.
Thanks Paul. Photos of Wasa show they used wood of so many different sizes, but the pattern was not evident from the photos. I guess for that ship, they were just interested in making sure as few end joints lined up as they could with the wood they had.I can't answer your question for the Syren other than to say if you are laying down a pattern just stick with that pattern - any side to side difference would then fade into the background (just my opinion not stating fact).
And to answer Kurt's question...
Complete chaos...
Yes, I think that's right Kurt. On both the decking and the hull planking Wasa does not show a standard plank shift or pattern. I read they simply used the available material to its best advantage.Thanks Paul. Photos of Wasa show they used wood of so many different sizes, but the pattern was not evident from the photos. I guess for that ship, they were just interested in making sure as few end joints lined up as they could with the wood they had.
Yes, thanks Paul. I have played with deck patterns for a couple of weeks now. Checked books, monographs, logs, photos and so on and most show that butt symmetry I asked about. There is one other way, actually two ways, nope three ways around it.I can't answer your question for the Syren other than to say if you are laying down a pattern just stick with that pattern - any side to side difference would then fade into the background (just my opinion not stating fact).
Complete chaos...
Hi Jack, those loose test planks were laid to give me an idea of where butts would fall. The manual shows one plank each side of the centre line. The first on the port side lands on bulkhead three (L on the plan). The first stbd one lands on bulkhead five (D on the plan). That butt shift throws off the deck butt pattern at the port and stbd sides but as Paul said it probably will not be noticed.About deck symmetry. Did you start the planking with the middle and then worked your away outwards? Meaning you do port side then starboard then port then starboard etc?
Great work Roger! I admire the depth of your research with the goal of following real hull planking rules and practices. I've read your build thread and forgive me if I've missed someone already suggesting. You could follow butting planking rules if you if you simulate the butt ends where they fall on the faux frames. When they fall on bulkheads use real butted ends. It does depend on your plank thickness and the thicker the plank the easier it is to pull it off. Normally, single planked hulls use thicker planks and hence my suggestion.
Whatever you decide, I'm quite certain you will end your planking journey with great results.![]()
