- Jan 9, 2020
Hello Jan. As I said, I can't take credit for this, this is what Piet did. I will try that out tomorrow. As to cutting the plank too short, I plank the full-length strip and afterwards cut off the excess with a sidecutter and then file into shape. The longer the piece of wood, the easier it is to bend.Hmm, I can see how your method works and like the result. I will try that on the SB side. But for the PS I’ve got to much “invested”.
I still need to re do the last or fifth plank, I got over confident cutting the length and wound up several millimeters short of closing the gap at the stern.![]()
Not to worry, I knew what you meant. The plank I just placed was tapered to 4mm.
