a beautiful hull - very good work and congrats for reaching this step
wonderful shapeThe transom pieces are now in place. Final sanding and application of wood finish next.
, well done Brilliant. Well done.The transom pieces are now in place. Final sanding and application of wood finish next.
It's like just about any POF-build is balm to sore eyes. Your build is no exception.The addition of the keelson was the last stage of this part of the hull construction, so now is a good time to apply the finish.The first coat dried completely flat but a second coat gives a slight sheen which l find quite pleasing. It's now back into the cradle for the cannon ports to be cut and the continuation of the rest of the build.
Thank you. If you go back to my post 121 there is a photo of what l used. Not sure if you can get it in the States. But something similar l expectOh yeah, really brings out the wood tone. Excellent.
What finish did you apply?
So beautiful…..wow. I Love itThe transom pieces are now in place. Final sanding and application of wood finish next.
DittoWhat a beautiful set of frames! Stunning really...
Do you like it Paul, or is it over done?Very brave dye job!
