- Aug 14, 2018
Keef's frames look perfect to me. JJ.KEEF has unfortunately not laid the frames correctly. Instructions are not good. I got it wrong buT put it right
Build the frames the other way around the single kee; piece should be on the to this means that the next 2 (5v and 6 i think) are flat. I al;so meens that you only ned single pieces of 1 mm piece of wood to build the rest of the kit up. WE are lucky that Keef has dne it before us
I had problems with bits moving so now i just do the first three let it set then do the next 4 and finally the next 4/6
THANKs
