Amazingly good work on what must be a most demanding task.
Hallo @Maarten,These are serious deck clamps Uwe. That must have cost a lot of steam and heat.
You can not find any clear drawing in the Anatomy book, or also no information in the contemporary drawings, how the inner planking was made .Hi Uwe. This is NOT criticism; I am asking the question because I am intrigued by this. I know that you are a most meticulous and experienced builder and that CAF's models are well designed and properly tested in test-builds. What could be the cause/s of these gaps in the bottom planking? Surely, something is not right here - those gaps are simply too big? Or are those gaps supposed to be left open?
Thank you very much for the reply, Uwe. As I said, I was just trying to understand all the factors that are at play here. Le Coureur did not seem to present the same issue, but she was obviously a much smaller ship and there were no mortar beds to take into account.You can not find any clear drawing in the Anatomy book, or also no information in the contemporary drawings, how the inner planking was made .
According Lavery often the inner planking was not completly pulled up or closed to towrards the clamps. Often the bigger ship of the lines had a carpenter walk slightly under the waterline in order to check the status of frames and the watertightness of the outer planking. For this the inner planking had to be open......
And in addition it seems, that I made a mistake with the installation height of the clamps towards the stern - at the bow it is definitely correct, but going backwards there is a problem, which I have to solve somehow. The height of the mortar bed beams have to be correct.
Maybe also an additional reason could be, that I started with the first inner planking rows to much fore, with this the gap would be also bigger.......
For a model designer like CAF, it is extremly hard to find the absolute correct way and prepare the planks that everything of such planking fits by 100% - unfortunately modelers are making mistakes, and CAF supported us with the plank "D" which is wider and suppost to be for adjustments
I personally decided to close the planking towards the clamps for the mortar beds and the area higher towards the deck beam clamps will be open (for the carpenter).
Later or at the end we know more
I have to be honest - also with the Coureur I had my personal problems (not caused by the kit) with the inner plankingThank you very much for the reply, Uwe. As I said, I was just trying to understand all the factors that are at play here. Le Coureur did not seem to present the same issue, but she was obviously a much smaller ship and there were no mortar beds to take into account.
No, I don't think that at all!I have to be honest - also with the Coureur I had my personal problems (not caused by the kit) with the inner planking
So I am unfortunately not the best inner planking modeler![]()
