HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
Considering that CLOU Schnellschleifgrund is just the sanding sealer the result is outstanding! How can I go with Schnellschleifgrund CLOU? :cool:
It is impossible to obtain it in the US. :(
Jim, see my post in my build log about the CLOU. Maybe there is a way.
Many Thanks for all your kind words and all the likes received
@Maarten : yes, a slight final "sanding" with steelwool is making the surface very smooth and brings a final touch
With the finished internal planking the riders of the mortar beds can be adjusted to the form of the planking
the photos are showing the dryfit before starting the final adjustments of the riders
Many Thanks for your interest
The necessary installation of bolts etc. I like to make before these elements are finally installed inside the ship.
For myself I realized, that I can do such works much more accurate outside with the single element in hand, than already fixed
So here the "bolting" of the riders is done - followed by the shown pattern of bolts in Goodwins Anatomy book about the HMS Granado
Very nice Uwe!
Like the square 'bolts' - may I ask what do you use?
Ted
Hallo Ted,
many thanks for your interest - These "square bolts" I used first time at the section model I made before - see this and the following posts
these are shoe tacks or nails with square shank 0,8mm
copied from the section building log:
From right to left:
1) small dott with a scriber
2) drilled hole of 0,8mm maybe 5mm deep
3) nail / tuck of 0,8mm square installed
4) nail driven with small hammer
5) nail head cut maybe 1 or 2mm above the timber
6) filing down with a needlefile
7) finished square bolt
and an actual photo I made yesterday
After the installation of most of the inner planking I was once more able to check and finally mark the heights and locations of the beam-clamps with the help of the temporary templates available in the kit.
In addition I checked the height also with the distance towards the lower sills of the gunports. This is in my opinion the most important measure, which has to be correct, because an error will be immediately visible when the guns (standing on deck planking, which are laying on beams installed on these clamps) are not fitting to the gunports.
Who cares if the hold is 2 or 4mm higher ..... especially if I plan to separate the deck from the hull along the wales
the bended ends of the 3mm thick clamps for the mortar bed beams
The first row is installed, bolts are simulated with square shank nails
The fore view direction towards the bow
and the other direction aft towards the stern
I was very happy with my last check, when I dryfitted the riders, the baoll rack pillars and the mortar bed beams - everything is fitting well, so that I can sum up, that the fixed clamps for these beams are definitely in the correct height
Now the second and third row under the first installed band of the clamps have to be prepared .....
Many Thanks for the interest ....... see you soon in this topic
