HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
These are serious deck clamps Uwe. That must have cost a lot of steam and heat.
Hallo @Maarten,
no steam - only watering some 10 minutes in warm to hot water - afterwards the plank is already much more flexibel. and finally with the Kolderstock bending iron with the smaller dip (in the middle of the photo). After checking the bend directly at the hull, maybe one or two more corrections (water and iron) it was working to be acceptable
The second row of clamps were bended, afterwards installation of the same square bolts with similar pattern like the installed one
I am by myself not 100% happy with the result - but at the end these clamps will be only partly visible - nobody will be able to have a view along the edges of these clamps -> so the result is acceptable
dryfitting of the riders
Many Thanks for your interest .... to be continued .....
Very nice Uwe, once again! Do you ever sleep?
I'm at the same stage at present, but without the internal planking. The bending of the beam clamps is extreme, particularly at the bows, but coming on nicely with plenty of steam and clamping! It can be done!
Ted
Hallo Ted,
I agree, Yes - it can be done....
not easy, but with the good quality timber and some patience it is possible to get an acceptable result.
I mentioned already the thrid clamp plank. In the kit you can find the plank "D" for the adjustments between the clamps and the inner planking
Looking at the cross section in the Anatomy book from Goodwin we can find the plank "51" marked with the red arrow as a thick stuff upper strake planking
so I decided to use the kit plank "D" and used the form as a template for a scratch plank of bigger thickness, so I prepared a 2,2mm thick sheet (with my small turkish thicknesser from Netmak) and praped this plank
starting point is the midship
also the bow - I used here copper nails as bolting in order to get a more visible difference to the clamps
and finally also the plank direction towards the stern
still there are some gaps of planking which have to be filled and closed
good to have the excess laser cut planking of the other side, so enough material for such filling pieces
and als the area at the stern are closed now, technically not really correct, but the planking is closed and "fixed" with treenailing
Many Thanks for your interest in my work and building log ..... to be continued ......
Hi Uwe. This is NOT criticism; I am asking the question because I am intrigued by this. I know that you are a most meticulous and experienced builder and that CAF's models are well designed and properly tested in test-builds. What could be the cause/s of these gaps in the bottom planking? Surely, something is not right here - those gaps are simply too big? Or are those gaps supposed to be left open?
You can not find any clear drawing in the Anatomy book, or also no information in the contemporary drawings, how the inner planking was made .
According Lavery often the inner planking was not completly pulled up or closed to towrards the clamps. Often the bigger ship of the lines had a carpenter walk slightly under the waterline in order to check the status of frames and the watertightness of the outer planking. For this the inner planking had to be open......
And in addition it seems, that I made a mistake with the installation height of the clamps towards the stern - at the bow it is definitely correct, but going backwards there is a problem, which I have to solve somehow. The height of the mortar bed beams have to be correct.
Maybe also an additional reason could be, that I started with the first inner planking rows to much fore, with this the gap would be also bigger.......
For a model designer like CAF, it is extremly hard to find the absolute correct way and prepare the planks that everything of such planking fits by 100% - unfortunately modelers are making mistakes, and CAF supported us with the plank "D" which is wider and suppost to be for adjustments
I personally decided to close the planking towards the clamps for the mortar beds and the area higher towards the deck beam clamps will be open (for the carpenter).
Later or at the end we know more
Thank you very much for the reply, Uwe. As I said, I was just trying to understand all the factors that are at play here. Le Coureur did not seem to present the same issue, but she was obviously a much smaller ship and there were no mortar beds to take into account.
I have to be honest - also with the Coureur I had my personal problems (not caused by the kit) with the inner planking
So I am unfortunately not the best inner planking modeler :confused:
No, I don't think that at all! :) I just think that concave planking is considerably more difficult to read visually.
Hallo my friends,
many thanks for all your kind words and comments - much appreciated
and also for the likes received - completely motivating that there is an interest in my progress
I finished also the clamps on the other side, so that I was able to treat the next areas with CLOU Schleifgrund - and I am by myself very pleased by the appearance ....... there for some more photos of this status, I hope you like it also
also fro everybody, who will build this kit, these photos could help as an example of how to make it, or not to make it (when I figgured out where my mistake, described in the previous posts, was)
First of all the birds view
and with a closer distance
the side views
and longitudinal
and for everybody not bored already
Looking good, or?
But......
interesting is this view where we can see some smaller inaccuracy in the line of the clamp
Very good, that later on with installed interior, the riders, beams and all this, nobody can look along the line of the clamps - the clamps will be everywhere only over a length of some centimeters visible - puh
Many Thanks for your patience to take a look at these photos ..... to be continued in short time with the mortar beds
Hi Uwe. let's ignore the view along the clamps (last picture) and focus on the actual planking. That is very well done and now that it is all closed up, it looks excellent. Your choice to opt for the CLOU was an inspired one - one simply cannot believe the difference that it makes! Looking good!
Witaj
Po co są problemy, po to aby je rozwiązywać ty to zrobiłeś bardzo dobrze pozdrawiam Mirek
Hello
What are the problems for, to solve them? You did it very well. Regards Mirek
Many Many Thanks my friends - for the nice comments and all the Likes received
I am very happy, that so much members and friends are following my building log - Great
Now it was time to go further with the beams of the mortar beds, which are based in the prepared notches of the clamps - hoping that the will fit in the height, because these are also laying on top of the shelves or better shell racks
-> each beam has 3 contact points on the 3 racks and left and right on the clamps - all of them should fit...... let us see
Beams are prepared and laying on the clamps - and you can see the base beam of the racks on top of the riders
and the same situation with the view from the top
the elements of one shell rack - On one rack 8 shells have their base - 6 racks all together, with 3 racks under each mortar
first dry-fit - some smaller sanding works are still necessary
and the finished racks
a first test with some of the balls / shells (included in kit)
prepared and ready to be installed on the riders
in my next posts you will see my report of the fitting the correct height
