A small project by itself..... it is looking very good.....
@ Zoltan: good question.....
Please consider making a Donation to SOS to support our continuing growth and developement. It is greatly appreciated !!! *** Read More - - Click Here *** https://www.paypal.me/DonateSOS |
Beautifull John, are you also fitting the canopy?
Regs Maarten
Nice work, John, as always!
I realised on Greg's kit that the oars had been manufactured with somewhath too thick blades, too thick decorations (on the original they were only painted) and that the handles were not rounded - do you intend to work on them or they will be left just like out of the box?
Janos
I was thinking along the same lines Greg, but I would use Plasticine to make enough copies plus a few extra ones, just in case, and then use car filler bog to make the copies, these could then be sanded down to the right thickness, gilded and maybe have a black or dark wash applied and then glued in position, the other option I was thinking about was to see if I could remove the carved decoration with a micro saw, sand it to thickness, then reglue in position, Ah food for thought.
Its nice to see all the dialogue going on between these three kits, and see the outcome of the three of them, I can see now with what Maarten is doing, and what you are planning that, we are going to have three very individual ships, I look forward to more updates,
best regards John.
A big improvement indeed. They are realy looking good.
In addition to the question Greg already mentioned I would like to know, what is this at the end of the oars?
Means the part which will be in the water.....
A decoration or something else? Thanks in advance
