Good morning. That is a serious redo- awesome. When I first saw the pictures I shared Heinrich’s view of just leaving it- maybe the photos hide some of the difference and clearly you just said no way. I definitely prefer the American walnut colour. A good decision for sure. Cheers GrantHi Heinrich. I really didn't like the look. I had removed the planking last night.
Spent a good part of the day (off/on) planking one side with my walnut.
View attachment 328996View attachment 328997View attachment 328998
I have a little more work to clean it up.
That is pretty much the standard way, although usually brass rod is bent 90 degrees and used as you suggest. Soft nails would work as well.Not sure how the provided gun port hinge's are suppose to work. There's no parts to insert into the eyes on the hinges.
But looks like only one side of the hinge is used and two pegs are inserted into the hull. I'm thinking I use some small nails, bend them 90 degrees, paint them black and use them with the hinges
I'm not sure that the doors shown are outside the hull. There may be just a small gap all around giving that impression. I believe they are flush or nearly so, and all gun doors must be flush with the outer hull planking.I'm gonna do it!! Been thinking about putting the cannon doors on the outside of the hull rather than flush. HERE's an excellent build with the doors on the outside.
