- Nov 10, 2019
@Oktay Yaylacıkoral
@Bosco45
@Uwek
First of all, I would like to thank you very much for the interest in my work and the nice comments. Also I would like to thank you for the many LIKES.
Continuation: Standing rigging for jib boom and flying jib boom - Bâton de foc et bâton de clinfoc
On a grommet strop (ring rope) as a base, the standing rigging for the jib boom was laid on top. Building on this, first come the footropes, which are slipped over the boom with a served cut splice. At both ends the footropes had a served eye for tying to the top of the bowsprit at the back eyebolts, to which the single blocks for the bowlines of the fore top sails were also attached.
In order to guarantee the sailors a secure hold during their work, knots were worked into the 22 mm (ø 0.46 mm in model scale) thick rope of the footropes at intervals of two feet, e.g. as Turkish head knots. In 1:48 scale, I think it seems quite sufficient in this case to make overhand knots.
After the abolition of spritsail yards in the 19th century, the jib boom guy and flying jib boom guy were often spread to the cathead by means of iron outriggers, thus giving the jib boom and flying jibboom greater strength laterally. Accordingly, this was also the case with the La Créole. The rigging was mounted on iron spike-like outriggers on the fore channels.
In principle, the jib boom guys perform the same function as the shrouds, hence their designation by the French, such as Haubans bout-dehors beaupré, which corresponds to the jib boom guy.
The jib boom of this corvette had two 22 mm dia. ropes on each side, one of which was stiffened with tackles and double blocks.
The jib boom guys were attached individually with served eyes to the top after the footropes, and as already described, led through the outriggers to the cathead to the fore channels for mooring. The area of the lead through the booms was served against rubbing.
Next came the jib boom stay, also a 22 mm dia. rope. This was slipped over the top with a served eye and attached to the iron martingale in a groove provided for it. Underneath, the two jib boom stays were slipped over as counterparts, which were then attached to eyebolts on the port and starboard sides of the bow.
With the already shown triple block for the bowlines and the fore topgallant stay, the rigging of the jib boom came to an end.
The following picture shows the rigging elements that were partially mentioned before.
The second picture shows the finished jib boom top. After all, six ropes have been laid there, as well as the grommet and the triple block strop.
And in the last step, the flying jib boom was rigged, as can be seen in the last picture.
Building on the grommet, the following ropes were stripped over the flying jib boom top:
- footrope ø 19 mm (ø 0.40 mm in model scale)
- flying jib boom guys ø 22 mm (ø 0.40 mm in model scale)
- pair of flying jib boom guys ø 19 mm
- strop with 2 thimbles for the bowlines
Finally, the fore topgallant stay ø 15 mm (ø 0.35 mm in model scale) could be passed through a disc in the flying jib boom top and fitted in the forecastle.
See you soon ...
@Bosco45
@Uwek
See you soon ...
