Of course Uwek, i just mounted the keel temporarily, but I will sand the blackened parts.I am looking forward to see the next working steps on this model
I love this ship - It is a really special and technically highly interesting vessel.
BTW: Will you remove the laser char from the edges?
Yes but look at the shapes of the lines of couples 43.1 and 43.2, they are different even though they will be glued togetherI am assuming that is the beveling line?
I can’t really judge because I do not have the kit but for safety do not glue anything yetYes but look at the shapes of the lines of couples 43.1 and 43.2, they are different even though they will be glued together
Thank you TobiasThe lines of the bevels are once for the outside and once for the inside.
I think it is correct - better the lines make for me senseI have a question, what is the use of the lines drawn on the couples? (see photo 3)
View attachment 335130View attachment 335131View attachment 335132
No - you need the given information on the parts - because you have with parts 43.1 and part 43.2 only one double frame which has to be faired on both sidesThank you Tobias
I don't understand what they are for. just a point in the inner or outer face would not have been enough?
...but then, she will turn her body to be HOYistick!!! Great job assembling the frames.Hello everyone, there will be sanding work on it![]()
