- Oct 17, 2020
Hi Jeff, have you tried to make a template for the ankles, by doing so you are sure that they will all be the sameThe gunwales and inwales are installed. Lots of clamps are needed to hold these pieces in place while the glue dries. There is some overlap on each side of the hull.
View attachment 338786View attachment 338787
I started on the oars for the ship. I used my mini-lathe to turn the end of the steering oar and then the steering oar handle pin that is fitted at a right angle nesar the end of the steering oar. It is basically a large belaying pin in appearance.
View attachment 338788View attachment 338789
