My little Victory
Hi Guys,
Now on to the forward bulkhead, it was made using a small piece of thin plywood, cocktail sticks, and electrical wire.
Added a little decoration to the ship’s side using fuse wire.
Sorry about getting my finger in the way.
Cut out the fitted the deadeye channels from scrap 1.5mm plywood.
I will fit the Deadeyes later.
Its a small scale but it is already beautiful!!!
Actually i am a bit late, but if you couldn't find other material for the windows you could make a jig and make them using ropes. Also if you like you could add dummy cannons made with a resin 3d printer, these printers can make very small pieces and you can glue them with CA glue if i am not mistaken.
I wish you the best!!!
John
John
Hi John,
Thank you for the suggestion.
I did think about using thin cotton thread on a jig to make it look like the window frames but I could not manage to do it.
I do not have a 3D printer and I don't think that I could learn how to use the computer software needed.
Hi Guys,
There has been a bit of a slow down of my little Victory build as I spent the last week In Hospital.
I am now back home.
So this build may take a bit longer than I had planed as I have a bit of a limitation on movement and energy at the moment.
But I am on the mend so hopefully I will be back to normal soon.
Anyway just prior to being rushed into Hospital I just could not resist any longer I had to throw some paint on.
I know the colour is not correct but most people seem to recognise the Victory as Yellow and Black.
I think she is starting to looking like HMS Victory now.
Hi Guys,
Decided to have a go at making the cannons and carriages using 5 x 1.5 mm strip planking wood.
The wheels are from cocktail sticks.
And the cannons are made from a BBQ stick.
I thought I would add this photo just to give you an idea of the scale of the Figurehead.
nice work - On an English Man of War they are Guns
Hense 104 Gun ship
That rope looks a bit thick
Hi richardjjs.
Thank you for your comments.
I looked at this photo and compared it to my cannons but unfortunately I had to use the nearest thread I had that was near the size.
This entire project is made from what ever I can find lying around and so far has not cost a thing.
I am very great full to our member Rsj for sending me the plans and instruction booklet at no cost to me due to my financial situation without his help I would not be able to make this model.
Thank's again Rsj.
Hi Guys,
Just a little update.
Managed to do a bit of work to my little HMS Victory.
Cut some 5mm x 5mm strip wood for the gun port covers.
Fitted the 6 cannons to the deck, unfortunately that was all I could manage for the day.
Hopefully I will be fighting fit in a few day and be able to do a bit more.
Hi Guys,
I am working on closing all the gunport’s using 5mm x 1mm strip wood cut into 5mm squares, (as I do not have the equipment to replicate the 96 half cannon barrel.)
To brake up the monotony of working on the gun ports I decided to give the copper on the bottom a bit of weathering, I think I may of overdone it though.
I managed to find a bit of copper pipe in the shed that had been there for some time, so I mixed up some Acrylic paint to try and get the same colour green.
20221030_085526.jpg20221109_092212.jpg20221113_160703.jpg20221113_160734.jpg20221113_160836.jpg
Had a go at painting the figurehead but I don’t have a small enough brush so had to paint it with a cocktail stick.
This is what I am trying to achieve or something similar.
great-britain-england-hampshire-portsmouth-historic-dockyard-figurehead-on-bow-of-hms-victory-...jpg
And this is the results.
