Planking continues. Planking on the hull bottom was completed and sanded on the port side. A gap remains to be planked on the starboard side.
The gaps are narrowing.
Final plank on the port side.
Port side after sanding.
The buttocks have much better shape than the original DeAgostini design. This is fairly close to the shape in Lely's Portrait of Peter Pett.
Smooth!
The final strips of planking on the hull were laid on the starboard side today. The hull was sanded with medium grit to remove plank edges, and then fine grit to produce a smooth finish. I tried a spot on the hull with some white spray paint, but that covered all the plank like except for seams that has slight gaps, which appeared unsightly. So, I use xylene to remove the paint. I would like to allow the plank lines to peek through the paint, so a fine, thin coat of white will be attempted next. I don't think there is a stain that can remove the yellow color from the wood without covering the seams. Any ideas?
This was a measuring tool used to estimate how many planks would be required to fill the planking gap on the hull. After bridging the remaining gap, you can estimate how much you need to reduce the average width of the remaining wood strips to close the gap such that those last few planks are about even in width.
Very thin washes or maybe watercoloursaw? I don't really like paint but I thought I might try this on the Discovery. Just very thin coats to hint at the color rather than a solid colour.
Było to narzędzie pomiarowe używane do oszacowania, ile desek będzie wymaganych do wypełnienia szczeliny w poszyciu kadłuba. Po wypełnieniu pozostałej szczeliny możesz oszacować, o ile trzeba zmniejszyć średnią szerokość pozostałych pasków drewna, aby zamknąć szczelinę, tak aby kilka ostatnich desek miało mniej więcej taką samą szerokość.
View attachment 341311Witaj . Pięknie wykonane pozycie ,moje gratulacje . Pozdrawiam Mirek
Well, it was time to try using the air brush again. Mine is an airbrush from 1987, given to me by a close friend along with an equally old compressor. The bottom of the hull was painted and lacquered. Then, the saddles were reinstalled on the baseboard and the model placed on them upright.
Materials for masking off the lower hull. The paint was mixed with airbrush medium to thin it out to the proper viscosity for the airbrush.
After masking, the hull is painted with a thin coat, allowing the plank seams to show.
Seams still visible. The airbrush applied paint in a much thinner coat than spray paint directly from a spray can. This will work.
Krylon Satin Finish is the lacquer I used to protect the paint. It adds a small amount of satin sheen to the hull.
Buttocks after laquering.
Letting the lacquer dry.
Preparing to reinstall the saddles so the model can sit upright again.
The saddles are reinstalled on the baseboard.
