Gute, saubere und genaue Arbeit
It remains a beautiful sight, such a special construction method with partial jigs. Nice and accurate work, Thomas.I have started the 2nd stage of construction, the construction of the underwater ship. For this purpose, an assembly facility is provided.
The individual parts.
In order to assemble the individual parts without jamming, the recesses must be filed a little.
The assembly device put together without glue, ready to receive the upper ship.
Test with the upper hull in place.
And so the construction can continue. One last test with a steel ruler to make sure everything is straight, and I can continue building.
Best regards
Thomas
I appreciate your careful and thoughtful approach here Thomas. A good example to follow. Merry Christmas to you as well. May you experience the full blessings of the season.View attachment 346641
The false keel was narrowed from 4,1 mm to 2,1 mm according to the instructions. The false keel together with the planks then gives the correct width of the real keel. (If all goes well).
The horizontal plates for stabilizing the frames had to be ground to match the shape of the hull. So far, everything is loosely plugged together. When everything is glued together the three front and rear frames will be adjusted to the shape of the hull. At the moment they are too fragile to work on.
The tools for the sanding work. Except for the electric belt sander, everything was done by hand.
I wish you all a wonderful Christmas season!
Best regards
Thomas
