Thank you ConsNZ..That is just so enviably awesome with a capital "A"![]()
Cheers
Oh wow this ship this build is coming to life.Work on the deck continues by glueing pre-made deck side. Two layers of planking creates this part of a ship, bulwarks will come later.
While this is drying, I researched some furniture for Columbo' cabin. Started with a simple table...
... which I did not like and find out some plans for medieval furniture I think will fit nicely in this model.
Testing the hight of the table...
Then I completed one chair. Very tiny stuff... table dimensions: 15mm (H) x 15mm (W) x 34mm (L), chair 17mm (H) x 7mm (sitting part hight) x 7mm (W)...
After completing one chair, overall bulkiness of table' legs and foundation showed up so I decided to lower the leg hight and to cut the leg foundation in half, which provided a bit more dimensional balance between chair and table.
Second chair was made as well; table has leg foundation cut in half and legs were cut for approximately 3mm in hight.
Bringing important figure to the picture...
Since Portugal left World Cup earlier, guessing signore Christoforo might be a bit upset so need to speed up ship building...
A layer of golden oak stain was applied to furniture ...
And ready for assembly..
Happy modelling..
"portamanovre" -- 'Porta' can mean either door or to carry. "manovre", maneuvers. Frank48 will know an exact translated meaning for this or it's English nautical translation. Great work I'm enjoying your build as i struggle with my AL SM.The rails were added to the upper deck. Kit plan asks for 1x4mm plank to be used in this case; dimension is working fine for port and starboard sides but not for stern. 1x4mm is not wide enough to cover thickness of the fence on that side (bulwark 2x2mm + planking 1x4mm + planking 0.5x4mm, + plywood 2mm = 5.5mm), so I put 2 1x4mm and will sand the excess.
Then I worked on rigging "rack" (kit is calling it portamanovre, not sure how to translate, if you know the correct term pls let me know), but basically the part that will be used to for rigging. This is before belaying pins are introduced...
I used 3mm metal pins, flashed with the wood to simulate the way of mounting/securing rack in place...
Then I marked the place where the rail on quarter deck will be installed; 4mm empty space... No cognac this time
After that is started to work on cabin windows, replacing the wired mesh that was originally installed. Just did not like it... The idea for this was from another SOS builder who completed Santa Maria.
So, the process.. First I made a moulding to cover plywood..
Moulding excess was sanded flash with the planking. Then started to frame the windows...
Once frames are done, I sanded them and cleaned any excess wood. Then work on windows started by adding 1mm strip in the middle.
Then bottom 1mm strips were added..
And the rest of the window with grilles... I used 0.3mmx3mm planking, out of cherry for grilles, cut them into very tiny strips and spent 2 hrs mounting them
I have some ideas how to make grilles more natural looking and will try on second window. If that works better will replace the first one..
Happy modelling..
Google translates is like "rigging port", or just rigging if the whole words is translated. I have Hystoric Ship models book with nautical terms in 5 different languages but was unable to find portamanovre..."portamanovre" -- 'Porta' can mean either door or to carry. "manovre", maneuvers. Frank48 will know an exact translated meaning for this or it's English nautical translation. Great work I'm enjoying your build as i struggle with my AL SM.
No need for clarification --Portamanovre - - Maneuver door/a point to start an action/maneuver. Italian rigging "Attrezzatura; standing/running rigging. Cheers.Google translates is like "rigging port", or just rigging if the whole words is translated. I have Hystoric Ship models book with nautical terms in 5 different languages but was unable to find portamanovre
Thanks, let me know if you need any clarifications..
Best of health and prosperity for the coming decades.Wish you all a good health in the New Year. Everything else will follow...
Happy modelling..
