Thanks its going to be a long road.Very impressed Tony P. Making great progress too!
Hi tobias,Hello Tony,
that looks very good. Here's how I went about it.
1. build the keel, bow and stern
2. Align the completed section on the top and bottom plates and check that everything fits at the right angle and then bolt the top section in place. I am adding pictures for you
If you’re referring to me, good luck! I’m a novice on scratch building models and understand that I know less than nothing. I do have extensive full size woodworking knowledge and some kit building success but have quickly learned that this is a whole new world!
Maybe Oliver's contribution will help. And Toni, importantly, you still need the wood of the keel with the notches.
Thanks Tobias, I suppose I could cut the frame bottoms off. I can then make new bottom "blanks" mill them properly then glue them to the frames. ? I could also make yet another rising wood with slots that fit my frames, same with the keelson above.
Oliver's Historic Shipyard he's talking about.If you’re referring to me, good luck! I’m a novice on scratch building models and understand that I know less than nothing. I do have extensive full size woodworking knowledge and some kit building success but have quickly learned that this is a whole new world!
Whew, thanks for clarifying. Now I can go back in my corner and ponder what the next step should be…Oliver's Historic Shipyard he's talking about.
Hi Toni, unfortunately I don't know how the Hahn method works exactly. That's why I put a video under information. I have also read in other forums that Herold has chosen this principle to simplify the frame construction and to be faster, neglecting the accuracy of the joints. I have also read that the ships are built upside down. I can't give you any tips on this, sorry.As it is now. If my frames are notched to fit over the rising wood and I make a new keelson with notched to fit over the frames why is that an issue ? When we use the Hahn method were taking the framing accuracy away anyway. From what I understand Hahn invented this method to make it easier to build a POF model. Comparing this method with the normal follow the plan method is a mistake I think. Id really like to find out how the frame bottoms "should" be done Hahn style.
It’s not an issue to me. I’d like to just continue as I am but I don’t know what’s right or wrong. See my message. Thanksi am not sure i fully understand the issue with the Hahn method
