- Sep 3, 2021
Thanks so much for your brutally honest opinion.it looks more like a chest of drawers for storing nautical charts rather than access doors ....
Do you by chance have a constructive observation to add?
**VIEW THREAD HERE** |
Good afternoon Johan.My two cents: The doors are good however to me they sort of detract from the style of the work around them. The white also makes them central focus. I think Peter is spot on with his advice and views. On my Victory as you know I did so many things “Grants way” and my litmus test - if it keeps bugging me, only then I change it. Cheers Grant, different aft cabin entry configuration. Now I need to let it soak and see if I like it sufficiently to let it stay...
Go for the sliding doors as per my previous suggestion.
P
So do I!I like that last set-up with the cover slid back and the doors set ajar.
Persevere! Everything opens a bit so you can look into the stairwell. Well done, Johan.I promised myself to let the new aft cabin entry soak for a while, but whenever I took a look, I was dissatisfied with what I saw. Y'all know what that means, don't you? Redo time!
Luckily I didn't throw the two hinged doors plus hinges into the dustbin, meaning that after cleaning up, I was able to use these parts again.
After a rather tedious exercise; dry fitting, sanding, more dry fitting and more sanding I again bonded the hinged doors to the door coaming. But, instead of bonding the hinges separately from the door and afterward installing the doors, I now bonded the hinges with the doors, using the latter as a jig of sorts.
After allowing the adhesive ample time to dry, it was time to try the doors and lo' and behold, they work!
Again I'll allow myself some time to see if I'm really happy with the current results.
The picture below shows the configuration with the sliding planks, working, but not so much for looks.
The pictures below show the latest hinged doors installation, both closed and open.
I still have like a plan "Z" as a backup, but that's an absolutely last resort and I have no intention to go there.
Good morning Johan. Ahh...now we are talking. I like the doors and sliding doors open. Cheers GrantI promised myself to let the new aft cabin entry soak for a while, but whenever I took a look, I was dissatisfied with what I saw. Y'all know what that means, don't you? Redo time!
I know I might have disappointed some people (@Heinrich?), but you're apparently not one of them!Good morning Johan. Ahh...now we are talking. I like the doors and sliding doors open. Cheers Grant
Thanks Peter, the hatch slid fwd and the doors ajar is indeed more convincing than everything closed.Persevere! Everything opens a bit so you can look into the stairwell. Well done, Johan.
You are a fast learner, Johan.Slowly but surely I find myself transitioning from hull to masts, booms, gaffs and standing and running rigging. There are still some leftover jobs for deck equipment (dories, amongst others) and simultaneously I started preparing spars.
I will not rehash previous discussions on this topic, but I do use the information @Peter Voogt collected in a spreadsheet on the (deemed) correct spar diameters.
Also, Peter offered to lend me his Proxxon lathe and after a Voogt Special Workshop, preceded by two failed attempts to use the lathe, I was able to either rework the YQ gaffs and booms or make new ones.
Next the lower- and top masts.
Oops: a) constricted and b) snapped...
The right part is a handmade replacement boom, prior to understanding how to use the lathe.
Main gaff and boom, both made from excess stock from a certain fellow modeler. I'm really pleased with the results; this is IMHO way more realistic:
Hello Johan, Sorry for your mist have on the lower main boom, but you did come out all the better and even with a much nicer looking wood.Slowly but surely I find myself transitioning from hull to masts, booms, gaffs and standing and running rigging. There are still some leftover jobs for deck equipment (dories, amongst others) and simultaneously I started preparing spars.
Good morning Johan. The final product is looking spot on. The use of a mini lathe. When Justin got me one for Xmas I thought I can now make things like Peter…I found out there is plenty skill and patience require to use a lathe and I’m still not getting my test work very good.Slowly but surely I find myself transitioning from hull to masts, booms, gaffs and standing and running rigging. There are still some leftover jobs for deck equipment (dories, amongst others) and simultaneously I started preparing spars.
You are a fast learner, Johan.But technology is no stranger to you.
Great results Johan. I also have no idea how to use a lathe - if I ever do get one, I will come and take classes. Your masts and spars look excellent!
Regards Lawrence
As I said, I received an individual workshop on how to use a wood lathe to make custom spars, plus, while I attended school I did some metal work; turning, machining, welding, etc, so I'm not a total newbie on using machinery.Good morning Johan. The final product is looking spot on. The use of a mini lathe. When Justin got me one for Xmas I thought I can now make things like Peter…I found out there is plenty skill and patience require to use a lathe and I’m still not getting my test work very good.![]()
