YQ Bluenose by Johan [COMPLETED BUILD]
P
Okay, different aft cabin entry configuration. Now I need to let it soak and see if I like it sufficiently to let it stay...
Good afternoon Johan.My two cents: The doors are good however to me they sort of detract from the style of the work around them. The white also makes them central focus. I think Peter is spot on with his advice and views. On my Victory as you know I did so many things “Grants way” and my litmus test - if it keeps bugging me, only then I change it. Cheers Grant
Go for the sliding doors as per my previous suggestion.
P
I promised myself to let the new aft cabin entry soak for a while, but whenever I took a look, I was dissatisfied with what I saw. Y'all know what that means, don't you? Redo time!
Luckily I didn't throw the two hinged doors plus hinges into the dustbin, meaning that after cleaning up, I was able to use these parts again.
After a rather tedious exercise; dry fitting, sanding, more dry fitting and more sanding I again bonded the hinged doors to the door coaming. But, instead of bonding the hinges separately from the door and afterward installing the doors, I now bonded the hinges with the doors, using the latter as a jig of sorts.
After allowing the adhesive ample time to dry, it was time to try the doors and lo' and behold, they work!
Again I'll allow myself some time to see if I'm really happy with the current results.
The picture below shows the configuration with the sliding planks, working, but not so much for looks.
The pictures below show the latest hinged doors installation, both closed and open.
I still have like a plan "Z" as a backup, but that's an absolutely last resort and I have no intention to go there.
Persevere! Everything opens a bit so you can look into the stairwell. Well done, Johan.
Good morning Johan. Ahh...now we are talking. I like the doors and sliding doors open. Cheers Grant
No disappointment on this side. One has to make a call and you can only follow one direction - so if that is different from mine, so be it. I had the same type of decision to make about whether to install a front wall for the center canopy of the WB or not.
Hi Johan, now it's ok!! I like It.
Slowly but surely I find myself transitioning from hull to masts, booms, gaffs and standing and running rigging. There are still some leftover jobs for deck equipment (dories, amongst others) and simultaneously I started preparing spars.
I will not rehash previous discussions on this topic, but I do use the information @Peter Voogt collected in a spreadsheet on the (deemed) correct spar diameters.
Also, Peter offered to lend me his Proxxon lathe and after a Voogt Special Workshop, preceded by two failed attempts to use the lathe, I was able to either rework the YQ gaffs and booms or make new ones.
Next the lower- and top masts.
Oops: a) constricted and b) snapped... Sick
The right part is a handmade replacement boom, prior to understanding how to use the lathe.
Main gaff and boom, both made from excess stock from a certain fellow modeler. I'm really pleased with the results; this is IMHO way more realistic:
You are a fast learner, Johan. :) But technology is no stranger to you.
Hello Johan, Sorry for your mist have on the lower main boom, but you did come out all the better and even with a much nicer looking wood.
Regards Lawrence
Good morning Johan. The final product is looking spot on. The use of a mini lathe. When Justin got me one for Xmas I thought I can now make things like Peter…I found out there is plenty skill and patience require to use a lathe and I’m still not getting my test work very good. Redface
Great results Johan. I also have no idea how to use a lathe - if I ever do get one, I will come and take classes. Your masts and spars look excellent!
Regards Lawrence
As I said, I received an individual workshop on how to use a wood lathe to make custom spars, plus, while I attended school I did some metal work; turning, machining, welding, etc, so I'm not a total newbie on using machinery.
What I initially did was to use a strip of sanding paper, about an inch wide. That'll give you a) pressure without counter pressure and b) a high risk of the result being not uniform.
I've learned now to use two pieces of sanding paper, a coarse one and fine one and holding those two pieces at opposing sides of the part. Also I learned to use a rather wide piece of sanding paper, like 2" wide and using one's fingers to spread the pressure more uniform over the part. It works like a charm.
A suggestion from my side is to avoid removal of too much material; don't try to remove like 0,080" or more, instead, buy yourself a spar, closer in size to what's needed. I found that removing up between 0,040"-0,060" is pleasantly feasible.
Using the lessons learned, I'm now able to satisfactory make some customized mast parts.
Anyone needing some instructions? I know who to turn to! :D
