Good afternoon Daniel. Thank you. The arrow just shows another chip I had to repair. The good thing about veneer is you repair fairly easily.Grant, I don't know what the red arrow is pointing at other than a really beautiful, well-constructed hull my friend!
Thanks PaulAgree with Daniel...that is some really fine work Grant.
Hello Peter. I had a look and I see what you are referring to. Some solace for you and I is that it is not our mistake but a kit error. I have no African Walnut and am hesitant to remove this. I will see what I can do when I come to place the rudder. Thanks you for the compliment it is much appreciated.Great progress Grant and it looks perfect. However the kit is wrong with the rudderpost. These gaps shouldn't be in there only on the rudder. I made the same mistake, corrected it later during my build. I had some trouble to fit the hinges correctly, that's when I found out the mistake. If you can correct it at this point during the build would help you later on.
Cheers Grant
The changes you made at the foremast are none like the kitdesign describes, but love it. Where did you get your inspiration from?
