Hi Mike41, I have a few questions as I am ready to order more materials for part 3 and 4, and need some verification on both the plans and BOM, but first 2 questions on the Frames, ONE I am on Frame No. 8, on the revised drawing you show PART 8-13 as revised that seems to work, but you also show Frame No. 8-7 it is completly different then Frame No. 8-1, AM I MISSING SOMETHING HERE, next one I am in a senior citzen mode of not getting my BRAIN to Work, HAVING dificulty understanding the beveling of AFT FRAMES 6-9, could you try to help me there,,,NOW TO Questions on BOM AND PLANS FOR PART 3 and 4 THE BOM says the DECK CLAMPS ARE 13/16 X 5/32 the dimesions on the plans work out to be LOWER DECK CLAMP 7/16 X 5/32 and the UPPER DECK CLAMP 11/32 X 5/32 am i corect in this,,,, LOWER DECK FRAMEING the BOM says 18 pcs lower deck planking( 1/4 X 3/32 and 7pcs 3/8 X3/32) question is where is the planking being refered to is it exterior or what (as an aside I have not heard the term FOOITWALLING before what is its function),,, also on PAT No 3 CROSS SECTION there is a gap between the footwalling  After the 3rd STRAKE, I also took the height of the cut off for the frames from the CROSS SECTION FROM THE BOTTOM OF THE KEEL TO THE TOF FRAME TRIM LINE is this OK, one other thing the CROSS SECTION  SHOWS LODGING KNEES KNESS I ASSUME THIS IS PART OF THE BEAM AM I CORRECT. that should do it for now, and should I post this on my Blanford Build MAYBE JUST YOUR ANSWERS. THANKS AGAIN FOR ALL YOUR KIND HELP. Don
