Outstanding Shota, I know that was not easy with all the tapering.
Hi Shota, brilliant, This was one of the logs that I enjoyed so much when I re visited the site after my break and was amongst some of the others that gave me inspiration to re start my build. Thanks for that. Kenthank you very much my dear friend's for your kind words and compliments![]()
it's my pleasure and pleasureHi Shota, brilliant, This was one of the logs that I enjoyed so much when I re visited the site after my break and was amongst some of the others that gave me inspiration to re start my build. Thanks for that. Ken
Such small items with the all those parts and tiny details gives a great result. Nice work, Shota.good evening dear friends
I spent the last week creating the pumps. They consist of a pair of 8 strips milled into a triangular shape and which need a lot of fine tuning to create the slanted octagon of the pump.
The pump is strengthened by 5 octagonal rings from a tin as well as the pumping assembly with the handle.
First I cut the triangles with a scalpel and then I sanded the triangles. it's required to produce an accurate octagon.
first I glued 4 triangles that came to two halves that eventually fit together as one pump.
Unfortunately, when I came to fit the five rings to the pump body, I discovered that it was too thick. Therefore I sanded gently to reach the required width. However, since in one of the pumps I was not able to maintain an exact octagonal line and slope, I made a new pump using the mf 70. I was only able to achieve a good result on the second attempt.
Later I painted the body of the pumps in
red (in the same shade as the other parts that were painted in the same color).
then I assembled the pump assembly parts with the handle and installed them on the pumps as well as the octagonal rings.
Finally I hand made two black wooden rings that would fix and connect the pumps to the ship's deck.
I am satisfied with the result I achieved after several days of hard work and while overcoming practical challenges.
wish all of us A pleasant and calm weekend
View attachment 386008View attachment 386009View attachment 386010View attachment 386011View attachment 386012View attachment 386024View attachment 386013View attachment 386014View attachment 386015View attachment 386016View attachment 386017View attachment 386018View attachment 386019View attachment 386021View attachment 386022View attachment 386023
With each posting your work gets better and better!
Very impressive. The pumps look great.
Jan
thanks my friend's for your kind words and compliments, I'm trying to improve my work constantlyOutstanding Shota, I know that was not easy with all the tapering.
my dear friendDid you install the center planking already?
How will you make the treenailing? or can you remove all the fittings.....
thank you very much my dear friend for your kind wordsI had to go back a few pages to catch up. Those hatches are great and the pumps very well done.
my dear friendVery good result - Looking good my friend
just only realized, that on some of the grids you made the small nail dott - on some not - especially on one you made the "nails" on half of the same grating.
I would do it everywhere
I tried two soldering heads (with a hole in the center) with the smallest head I have with a total diameter of 0.5 mm and I liked it because of the visibility even though in terms of proportion in reality the nail had a relatively small diameter.
I'm not sure I understood you correctly, I'd appreciate it if you could mark on a picture the place you think needs to be fixed and I'll gladly check it out.Hi Shota, it‘s looking really good.
Are your sure that the openings of the gids are not to big? If you have a look to Uwe‘s log, you will see that the timbers have thewrong direction.
I do not know, if you want to change it, perhaps my hint can help someone else.
Good morning Shota. Bravo! Bravo. Cheers Grantgood evening dear friends
The finishes were done
View attachment 386490View attachment 386491View attachment 386492View attachment 386493View attachment 386494
