Excellent work Daniel. The choice between the Aspen and the Pear would obviously depend on personal preference (I like them both), but you certainly do not have to worry that the Pear looks out of place. In fact, it creates a very integrated look at the stern.
No not at all out of place. But whereas the Pear and Walnut create an integrated look, the Aspen Walnut combination creates contrast, which is also good. So pretty much a case of six of the one and half a dozen of the other.Thank you Heinrich !!! . But let me ask: Why do you think that Pear wood could looks out of place ?
Daniel
Good morning Daniel. Way to go !! I am really happy that you decided to go for it and do this. Excellent.Cheers GrantGuys, after reading this morning all your encouraging words, I decided to leave beside my internal depression and give a try to the unglue process.
After a few hours of soaking all in alcohol and a few sections with Goof Off, for superglue, I was able to get all out.
And I saw the origin of my mistake. We need to cut the win transom to allow the stern post to fit on it. I did that cut precisely. Then took it out to mill a wider rabet. When I returned, placed the win transom and stern post on its place, centered, glued, and for some reason I moved all to the left without realizing. Put a weight over it and gone. Later on the day, I saw that the win transom was protruding more on the left than on the right side. But didn't light a red light on my brain, because I was going to sand all at the end.
Now you can see that the stern post fits in a wider cut on the win transom.. That will be visible after the planking. I will cover it with a thin plank and all will be remembered as a bad dream.
THANK YOU ALL AGAIN !!!
Daniel
Major disaster?
Like it never happened!
Thank you all for the nice comments and the likes !!!!VERY NICE DANIEL, GREAT FIX I AM LEARNING FROM YOU AND OTHERS, KEEP IT UP. GOD BLESS STAY SAFE ALL DON
Nice work Daniel.
Thank you Mike and Uwek and to all the likes.Much better stern timbering - and also the types of wood are fitting much better
Good that you made the repair
Thank you Paul, much appreciated. Also thank you to all the likes !!!Very nice Daniel!
Very good details with the thick stuff and in principle with using these bilge limberboards - the different kind of woods are beautiful
Maybe only two points which are necessary to discuss:
The stern section also includes the mizzen mast, so you have to add on top of the keel the mast foot or base -
here the limberboards are not installed so you will have an open are, where no limberboards are laying, so I think first the mast step has to be fixed and than you can adjust the limber boards accordingly
Here an excerpt of my Granado drawings
And I think the boards would not be higher than the surface of the keelson (red triangle) - maybe you reduce poartly the width of the board and adjust one edge
Granado
View attachment 389918 View attachment 389920
Very nice work, Daniel! I’m glad you didn’t end the project with the misplaced stern post. Good job!
BTW: I’m not getting email notifications for posts on this thread. Admins: Why?
Thank you Heinrich !!! I really appreciate your comment.Very good progress Daniel. I think the sanded center section looks far more integrated now. The inner planking adds another dimension to the build and as Uwe said, the different wood colors look beautiful.
