The Schooner Bluenose 1921, POF Yuanqing Models 1:72 [COMPLETED BUILD]
I'm afraid I own an even older one. Always works though...
What’s a calliper??? ROTF. Grants method- hold it up to the light and it looks about right.;).
Seriously tho Daniel, awesome as always. Yep with Peter viewing your build you have a walking encyclopaedia of the BN giving some pointers. Enjoy. Cheers Grant
wow. I didn't know this existed a POF Bluenose.
Congratulations on a job well done.
Looking forward to following your build log.
Thank you, very kindly and welcome aboard sir. Check out our Bluenose Build Group, there you will find some of the most spectacular build logs and their authors to be found anywhere in the land.
Good afternoon, all my end of the forum seems quite on this holiday weekend, I've been working on the bobstays at the bowsprit. I have decided to stay with my special scale for most all the rigging including the bobstays. LB Jenson states the upper and lower stays are iron rods (circ. 3.25" and 4.5") on the BN 2. I've researched what the materials might have been on the original BN but cannot find anything, so I assume the original had iron rods as well. I used 1.0mm and 1.5mm brass tubing painted silver to represent the iron rods. I can see in these closeups I need to tension the bottom stay a little more.
See what you think.
A work in progress hope you enjoy.
See what you think.
View attachment 392596View attachment 392597
It’s looking nice, Daniel.
And you are fully correct about the Steel Bars what Jenson wrote on pag.20.
I was stuck on pag.19: Rigging - all rigging to be of galvanized plow steel with shrouds, stays, sheets and halyards, according to rigging plan.
Perhaps for me a re-do …….. ;) No, we know the differences and imperfections …….
And Chapelle wrote: Wire rope for standing rigging was introduced prior to 1885. A wire rope bobstay was the same dia. as the jibstay, and was set up with a turnbuckle under the bowsprit in a heavy wye.
So, both are ok.
Very nice touch on the bobstays, Daniel; they are keepers.
Funnily enough your bobstays show the same phenomenon I observed on my bobstays; they converge at the bow instead of at the tip of the bowsprit. I recall having used the YQ drawings to determine the attachment points. Probably should have used the MS drawings instead.
The rigging of the bowsprit is a project of its own; lots of small detail work with limited room
Beautiful work, Daniel. Those solid stays give a totally different look to the ship - all for the better I may add!
