Uwe, there you make a clean diligence work which is really worthwhile. Very nice.
Bending the original part would mean, that you have to bend it against the wider dimension of 8mm which is extremely hard to make. The thickness of 1,5mm would be no problem, but 8mm could cause much bigger problems - it is much easier to cut out a new top rail with the correct formI'm curious as to why you couldn't use the factory sheer rail. It doesn't look like it has to move much. Wouldn't it bend into shape until the glue dries? Or is it a lot stiffer than it looks?
I do not know exactly, but I think they are around 5mm wide - my treenails are 0,5mm in diameter.Uwe,
I just reviewed your tree nailing techniques, very nice. Later this week I'll be doing the same on my San Felipe. How wide are your deck planks? I plan on swapping out the provided (low quality) ZHL planks for some 0.05 pear vinier.
A very nice fit of the rail top besides the cathead and following the bow curves, Uwe.Sheer rail top -scratched in pear, so that the complete rail is made out of the same wood
Starting with the first part from the bowsprit toards the cathead - the end at the bowsprit will be adjusted afterwards when the bowsprit will be installed
and further
all dry fit until now, they will be fixed when I have all parts prepared
Many Thanks for your interest - to be continued .....
Here we goReally beautiful work Uwe, how about a couple pictures with the whole model in there please? Haven’t seen a full shot for a while, the close ups are awesome and show your meticulous craftsmanship but I would love to get a complete view? Just if you think of it please… awesome, just awesome!
DittoDear Uwe,
Your attention to detail and pursuit of perfection inspires us all.
