with the anchor in place, she is ready for voyages, but...booms first. She looks great, Daniel! Good modeling skills.
And what a bow it is! Brilliant!this finishes the deck fittings at the bow
Thank you Jim.with the anchor in place, she is ready for voyages, but...booms first. She looks great, Daniel! Good modeling skills.![]()
Not even a chance of that happening Johan.Now I'm feeling severely outclassed...
Thank you, Paul, it is such a pleasure working and sharing with you and everyone on this forum.And what a bow it is! Brilliant!
Good morning Daniel. Ok……you have outdone yourself with this BN! The bow section with its many fittings and anchors is wonderful. Cheers GrantI finally received my kedge anchors. Dry brushing and installation were straight forward, this finishes the deck fittings at the bow.
View attachment 401041View attachment 401042View attachment 401043View attachment 401044
I made a little progress on the booms and gaffs by adding the clappers and two pulleys at the end of the main boom.
View attachment 401045View attachment 401046
I'm still waiting on a shipment of triple sheeve blocks, in the meantime I'll continue rigging the booms and gaffs.
Thanks for checking in.
I so would love to fly one of those (myself of course).Louisiana Kid do aerial maneuvers in his P51D
Agree, but also clearly showing the deathtrap it was...The bow section with its many fittings and anchors is wonderful.
Thanks Grant, the challenges presented by these models is irresistible, isn't it?Good morning Daniel. Ok……you have outdone yourself with this BN! The bow section with its many fittings and anchors is wonderful. Cheers Grant
Can you imagine dropping anchor with ice and snow on that crowded bow! One slip and you ground up in the windlass draw works.Agree, but also clearly showing the deathtrap it was...
In this pictures it shows that the pole stay is removed:Good morning, all, I was wondering if anyone knows if the Main Boom pole stay, piece # 125 is removed on the real Bluenose when she is traveling under sail.
It is hard to tell for sure looking at actual pictures of her under sail.
When under sail, the poles are not needed to support the booms; the air pressure/under pressure in the sails generate an upward force, which is being absorbed by the boom sheets.In this pictures it looks that the pole stay is removed:
(Source: Nova Scotia Archives)
This answer from Johan:I was wondering if anyone knows if the Main Boom pole stay, piece # 125 is removed on the real Bluenose when she is traveling under sail.
is the answer that the pole stay is not useful during sailing. But not the answer if the pole stay stays permanent on deck during sailing. I suppose that when the sails where set, the gaff is already lifting the sail and boom out of the pole stay. But the pictures shows: it does not stay, it's removable.When under sail, the poles are not needed to support the booms; the air pressure/under pressure in the sails generate an upward force, which is being absorbed by the boom sheets.
Once the sails are flip furled, the total mass of sails and booms and gaffs is supported by the pole.
Those old black and white pictures are something else and transmit a sense of drama, often not present in the colorful pictures we're used to.It remains an intriguing question, Daniel:
But you can ask the same question for the fore boom pole stay in front of the main mast. In terms of location, it is less of an obstacle for the crew. But it can also be made removable through a suitable recess in the fife rail. It just needs to release weight downwards.
In the 3 pictures in my post above, it's not clear. On this one it does:
It is still fun to study the old photos.
Also interesting on this pictures: only ratlines between 2 shrouds. Obvious a picture during racing. Captain Angus Walters removed all unnecessary weight. Even the normally placed double ratlines.
It looks as if he removed the nav lights as well...It is still fun to study the old photos.
