Better to recognize you ..... I will get used to them / thisHaha, you have to, Uwe. At least for the next .. years!
But is this one better / more specific?
Thank you, Paul. I still find it unimaginable that all this is possible with one 111-year-old drawing made by hand.Brilliant!
That's not necessary, Stephan. With a simple action I have the right size in Photoshop and I can do all the extras with it. And then a TIFF is much more useful than a PDF.I convert the drawing in AutoCAD to pdf in scale. It is very simpel to do. I can explain. Just call me when you have time.
Is that accurate?That's not necessary, Stephan. With a simple action I have the right size in Photoshop and I can do all the extras with it. And then a TIFF is much more useful than a PDF.
The most accurate as possible in this situation. But you have to know what you do. (In resolution till 3 digits behind the comma)Is that accurate?
Thanks, Jim. Most appreciated. A bit of an old professional deformation.I love your methodical approach to modeling, this is something I am badly missing...but developing![]()
as long as it does, you never know ……but developing
…..OH Boy….!Enough drawing, time to further adjust the building jig to start building.
2 pieces of drawing of the line plan are glued to the 2 tiltable parts, along the construction beam (see A+A)
Both aligned with each other, of course.
Then I can place a template on the correct line, in this case for frame 51:
Now it’s still one piece, but soon it will be cut in half. I can align both parts perpendicular to the construction beam.
Also glued on the base plate are 2 pieces of drawing of the line plan (see B+B):
These are glued in such a way that I can place the tiltable parts on them in such a way that they both have a 1.5 degree angle. Because the keel slopes 1.5 degrees from front to back.
The white arrow shows that the edge of the base plate is sloping relative to the bottom of the tiltable part.
Now the two lines for frame 51 are in line with each other and are therefore perpendicular to the waterline. They are tilted forward by 1.5 degrees relative to the keel.
I can later align the half molds on these lines:
See white arrow, the paper version is for the image placed slightly next to the line.
And I can also align the top of the frame to deck height, the line just to the right of the arrowhead.
First cut out the part of the bulkhead from the template made in Photoshop. I will build the frame on that part and a 2nd print.
Then cut both the frame and the mold in half.
That's the theory. Now on to a practical test.......
Cheers GrantThanks for your optimistic response, Grant.…..OH Boy….!. I know you know what you are doing- I’m lost
Cheers Grant
Hi Daniel. Thanks for the compliments and visit. I am glad you found the log and your interest for the build. Still seat available.Wow Peter, fantastic work. As usual I'm late to the party but so glad I made it. Your approach to modeling the hull surface looks to be spot on. Over the years I have done quite a bit of surface modeling using field data topographic shots to figure dirt quantities, excavation, backfill haul off etc. Occasionally I would set a scale expansion factor say in the z direction to help spot any abnormalities. Sometimes subtle irregularities will show themselves, just a thought. What I see in your 3d surfaces look really smooth though. I think you have a unique and fascinating scratch build going here. Thanks for sharing.
PS now I understand your avatar.
Thanks, Alessandro. I am also happy with the result. Hoped in advance, but certainly not expected.Ciao Peter.
Il tuo lavoro con Fusion è impressionante sei veramente bravo.
Hello Peter.
Your work with Fusion is impressive, you're really good.
You're absolutely right taking the line plan as your starting point, no questions asked.First major difference:-
On the lines plan the dimension between bulkhead 51 and waterline point on the keel/bow frame is 1550 (mm = 1.55 mtr), see circle at the bottom.
On the Construction plan this dimension is 1500.
To process all dimensions during construction, I have to take the dimensions on the line plan as a starting point.
