Did you make it, or did you purchase it with the t-slots?Hello Korsar, what exactly do you want to know?
sorry my mistake
Tobias my dear friendHave a wonderful good Sunday evening everyone. A little update, this week I started with the rear, I can tell you it's pretty tricky, well that's how I wanted it. I had to redo frame 52 and 53 on the port side. The following error happened to me with the No. 52: I misinterpreted the plan and milled the notch for the fashion piece a little too deep. For No. 53, I glued the double frames mirror-inverted.
See you soon.
Ps.: Thanks to everyone for your comments and likes.![]()
Dear Tobias, Thank you very much for your detailed answer, I really appreciate itHi Shota, you can actually take all the measurements from the plan, but I admit that you have to switch back and forth between 2 or 3 plans from time to time.
Maybe a few pictures will shed some light on this.
In the ascending wood you have the notches (picture below) for the crossbeams a, b, c, d and e (picture above) and if you have done everything correctly when preparing, you won't be able to get out. Use a piece of 7mm for crossbeam a, then glue it and cut out the top view first.
Then cut out the side view and glue it on and then work out the curvature with a sander, e.g. a spindle sander.
A little hint in the plans you will always find grey shaded pictures (see second picture) this is the cross-section of the component and here you can measure the height and width of the beam, for example.
Here is another picture I think I have not published maybe it helps a little.
Hi Oliver,As usual great looking work. Will you please let me know if these clamps are hand made or where I purchase them.
thanks!
That was quick! Thanks Jim it really helps when you know the name of a thing in order to search for it!Hi Oliver,
These are called Machinist/Toolmakers Parallel Clamps. While you can certainly make it yourself, here is the link on Amazon (not necessary for you to purchase from there)
Thanks Tobias. I too am deciding on how best to make some. I’ve looked at a bunch of YouTube videos for insight… we’ll see.Hi Oliver, Jim has already explained everything. I bought them from a German manufacturer, but I would like to build some myself from wood.
I can only agree with you Jim SOS is a wonderful forum. It's a place to feel good, you get help, constructive criticism, valuable suggestions and the knowledge of builders is gladly shared, last but not least -> good mood and humour.It just happens I was near my PC, therefore jumped to answer...but you are certainly correct, it is teamwork! SOS is a unique forum, where we strive to help each other!
