- Aug 8, 2019
You never grew up, bud skilled you are.When I grow up I want to be as skilled as you are Herman... Beautiful!
nice work @Herman
Thank you Paul. The only thing I can say to that is that that feeling is mutual. As long as we grow up together I would like to borrow some of your accuracy.When I grow up I want to be as skilled as you are Herman... Beautiful!
A nice piece of work, Herman.Together with the last 2 rows of planking the sternpost will have to be glued to the model. Before doing that I wanted to check how the sternpost would fit in connection to the wing transom. The easiest way to check that is simply to make the wing transom at this point (and a welcome short break from planking).
This is how the wing transom was drawn by Willem van de Velde:
I started with a piece of wood, that had been made to fit into the recess in the planking on the model. The profile on the underside of the transom was copied/filed into a piece of metal and with that piece of metal the edge profile was scraped into the wood.
At that point I had to mill a slot into the top of the transom and that went wrong as I had started with a piece of wood that was already beveled to the angle of the stern I had to counterbalance that angle. I simply made a piece of wood that corrected the angel, but it slipped during milling and damage the transom.
I started all over again by making a new piece of wood with the correct curvature to fit into the recess but this time no beveled angle. To get the milling over with I started by making the slot.
And scraping the profile again to the underside of the transom.
Enclosed two pictures of the wing transom provisionally place on but obviously no glued to the model. I have sanded it somewhat down, but it still needs a bit more work as it should only just protrude beyond the planking. A carving of a series of acanthus leaves belongs in the groove of the transom. That will be quite a challenge for later as the height of the slot is only 4,5 millimeters (abt 0,18 inch).
Thank you Peter.A nice piece of work, Herman.
Dear Herman
I had missed your birthday, I believe that was a happy& great birthdayI wish you all the best, happiness and many more years of happiness with your family and with the hobby
by the way, great work and progress
Thank you Heinrich, I am doing the best I can, plank by plank..This is beautifully symmetric planking my friend. You are building a special 7P.
A very fine plank job, Herman.The sternpost and the second to last row of planks have been installed.
And the overall view.
Now onto the garboard strake.
True storyFantastic Herman! Beautiful symmetry and lines. Perfect fit to the sternpost. I can’t wait to see some finish on this hull. She’s going to be majestic!
