…..very coolIt's pretty cool.
DittoThis is just incredible work. Even in a fantasy world, those double cannons in the turrets are inspiring and awesome to say the least!
Mr. Heinrich,This is just incredible work. Even in a fantasy world, those double cannons in the turrets are inspiring and awesome to say the least!
Mr.GrantTyler,…..very cool
You can be very well satisfied, my friend - those look superb!-fabrication -
The shank, crown, and palm of the anchor were all made of cypress wood. The ring is 1mm thick brass wire, and the stock is also made of cypress wood.
I took pictures from different angles, so I will post the images.
The hoop (iron band) attached to the stock will be made of copper plate.
Preparation for painting.
I applied a brush of Tamiya's surfacer to the shank, crown, and palm areas to break up the grain.
- Paint the anchor -
Paint the surfacer coated area with Tamiya acrylic color "Flat Black". After the flat black was dry, I mixed PEARM.RED, PERM.SCARLT and COBALT BLUE of Turner acrylic gouache to make rust color, and painted it with a rough dry brush. The stock was coated with OILSTIN (walnut).
The first rope (thin thread) was wrapped around the brass ring part.
White arrow part of brass ring section, second rope (thin thread) wrapped around four places, thinly coated with lacquer-based dark earth.
The white arrow part of the stock section, I made a hoop out of copper plate. I silver brazed the hoop instead of soldering it because of the force applied when fitting it.
The hoop made of copper plate was dyed black, and the parts that were unevenly dyed black were coated with a thin layer of lacquer type matte black.
The wooden stock was coated with Tamiya's PANEL LIN ACCENT COLOR (BROWN).
I made an anchor made of cypress wood and painted it to look like that.
It looks like an anchor to me, so I am self-satisfied.![]()
Mr. Heinrich.You can be very well satisfied, my friend - those look superb!
You have fantastic fabricating skills. And the paint job is top notch-fabrication -
Paint the surfacer coated area with Tamiya acrylic color Flat Black.
After the flat black was dry, I mixed PEARM.RED, PERM.SCARLT and COBALT BLUE of Turner Acrylic Gouache to make rust color and painted it with a rough dry brush.
After it dried, a 4B pencil was rubbed on.
The hoop made of copper plate was dyed black, and the uneven areas were coated with a thin layer of lacquer type matte black.
Hello swampdweller126.You have fantastic fabricating skills. And the paint job is top notch
Good evening. Brilliant and thanks for showing the process. The belay pins made from toothpicks are incredible. Cheers Grant- Making Fife Rails -
First of all, I need to make parts.
At first, I drew a drawing of a fife rail and printed it out on copy paper with a printer.
The drawing is attached to 0.6 mm aviation veneer.
A 0.5mm-thick cypress wood is attached to the back of the aerial veneer.
Before cutting out, the first step is to drill holes.
Next, cut from the inside.
Next, cut the outside.
It's the same with plastic board crafts.
First you drill the holes, then cut from the inside, then the outside ......
The processing order is the same for both wood and plastic boards.
The first one was cut cleanly, so the second one is in the middle of the cut.
The second piece is ready.
I'll cut four more.
It takes quite a long time, doesn't it?
Finally, I made six of them.
I made a fife rail for the foremast.
It took me a bit of time to decorate the upper part of the columns.
Temporarily assembled on the bow section.
This image is viewed from behind at an angle.
This image is viewed from the diagonal front.
This is good.
After this, German gray was applied.
I shaved the tips of toothpicks into the shape of belaying pins.
It took about 40 minutes to sharpen 10 pieces.
After that, I shaved 10 more.
It was cut apart, coated with wood oil, and set on a fife rail.
After setting the belay pin on the fife rail, it is set on the bow foremast section.
It took us a whole day to make this fife rail.
Next, the main mast fife rail was made.
Hello GrantTyler.Good evening. Brilliant and thanks for showing the process. The belay pins made from toothpicks are incredible. Cheers Grant
Hello, Mr. Heinrich.For me those rails would probably have taken a week (each)!Wonderful work, my friend!
Hello Mr. Uwek.A clever method for making these pins - with very good results
Many thanks for sharing
