Le Requin by Zhl - MY FIRST POF MODEL
Look at this part of deck planking: on the right is still rough, on the left is finished.
It's interesting to note how white maple reacts to polishing: I applied just neutral oil and wax but the change in tone is marked to the point of changing color too.
Good morning. This is a beautiful ship. So good. Cheers Grant
Waiting for finishing to get dry, some food for thoughts...
the crowd was gathered and an eminent scientist came on stage to say:
"it is scientifically proven that people with light eyes are smart, while those with dark eyes are stupid".
The crowd split into two groups, and those with light eyes began to mock and discriminate against people with dark eyes.
After some time another scientist came on stage and declared:
my colleague was a stoner, it is scientifically proven that those with dark eyes are smart; those with light eyes are stupid.
So those with dark eyes took their revenge and began to mock and discriminate against people with light eyes.
Some time later a philosopher took to the stage and proclaimed:
Listen! It is now scientifically proven that when you are in a group all of you are morons, regardless of the color of your eyes.
:p
Alessandro, bellissimo lavoro , complimenti !
My next model will probably be a kit like yours, so please i have some questions :
- What kind of finishing did you give when preparing the frames parts ? Were they gently sanded to remove the laser cut marks ?
- Do you intend to age the entire model ? Will you apply natural wood oil or some synthetic varnish ?
- What's the brass wire diameter you use to simulate the nails ?
Thanks,
Thanks,
Thank you!
All the pieces have been sanded, of course, till they get smooth; I use sandpaper of different grits for this purpose.
Yes, the aging process is related to the entire model but with different gradations, depending upon the part the I'm treating. For instance deks have been treated in a very light mode otherwise they get dark. You also have to consider the essence you are working with: cherry wood is lovely to work with, it allows to do whatever you want, meanwhile maple is completely different, must be very careful with it.
Anyway my taste is to be very discreet with aging because when it is too much evident, although you make a professional treatment, it looks false.
For finishing I always use oil and wax only because with synthetic varnish it looks like plastic material and I hate plastic:)
About nails, you have to refer to reality and calculate the scale: in reality diameter nails was between 2 and 3 cm.; they were of different type depending upon the part to be nailed, so in 1:48 scale diameter should be between 0.4 - 0.6.
Anyway, the most important suggest is the following: albeit you can find high quality kits, none of them is perfect and detailed as they should be, so if you want to make a quality model, it is mandatory to help yourself with some good modelship monographies; thereafter you will find that monographies too are not always correct, so often you are requested to add a bit of yourself while modeling and to do this you have to know your subject.
Thank you!
Alessandro, grazie per tutte le informazioni.
As for the aging processes, I think exactly the same as you, it's necessary to use natural products and always respect the characteristics of each material ( wood )
that is being treated. The result must to look natural, without exaggerations.
Continua a inviarci informazioni sul tuo lavoro !
Luiz Bruno Grassi
