- Oct 12, 2022
Where did you goget the center part of the clampsPlanking the deck one strip at a time, it looks the most obvious and simplier idea.
Thank you Mark for your suggest.
Those clamps are not so strong but they are enough to keep in place a single strip and they need very little room.
Good morning. This is a beautiful ship. So good. Cheers GrantLook at this part of deck planking: on the right is still rough, on the left is finished.
It's interesting to note how white maple reacts to polishing: I applied just neutral oil and wax but the change in tone is marked to the point of changing color too.
Amati modelsWhere did you goget the center part of the clamps
Thank youAmati models
Very nice planking sirLook at this part of deck planking: on the right is still rough, on the left is finished.
I appreciate your congratulations, thank youVery good work - I like it very much
Alessandro, bellissimo lavoro , complimenti !
Thank you!Alessandro, bellissimo lavoro , complimenti !
My next model will probably be a kit like yours, so please i have some questions :
- What kind of finishing did you give when preparing the frames parts ? Were they gently sanded to remove the laser cut marks ?
- Do you intend to age the entire model ? Will you apply natural wood oil or some synthetic varnish ?
- What's the brass wire diameter you use to simulate the nails ?
Thanks,
Thank you!
All the pieces have been sanded, of course, till they get smooth; I use sandpaper of different grits for this purpose.
Yes, the aging process is related to the entire model but with different gradations, depending upon the part the I'm treating. For instance deks have been treated in a very light mode otherwise they get dark. You also have to consider the essence you are working with: cherry wood is lovely to work with, it allows to do whatever you want, meanwhile maple is completely different, must be very careful with it.
Anyway my taste is to be very discreet with aging because when it is too much evident, although you make a professional treatment, it looks false.
For finishing I always use oil and wax only because with synthetic varnish it looks like plastic material and I hate plastic
About nails, you have to refer to reality and calculate the scale: in reality diameter nails was between 2 and 3 cm.; they were of different type depending upon the part to be nailed, so in 1:48 scale diameter should be between 0.4 - 0.6.
Anyway, the most important suggest is the following: albeit you can find high quality kits, none of them is perfect and detailed as they should be, so if you want to make a quality model, it is mandatory to help yourself with some good modelship monographies; thereafter you will find that monographies too are not always correct, so often you are requested to add a bit of yourself while modeling and to do this you have to know your subject.
