FWIW, my 1:96 hull enjoyed quite a bit of shaping (sanding) after planking but turned out smooth as butter! I think your initial buildup is going well and that shaping will take care of any high spots (if done with a sanding block) just fine. But, then again, I have not completed my first model yet, so take that with a grain of salt...Upon low angle review, I discovered an area of concern. I thought the bulkheads were carved and sanded to the proper angle. The planks appeared to be flat on the bulkheads when clamped.
I assume that I will need to sand this area to relieve the high spots?
