The Bluenose II/III was build/restored against the applicable regulations of that particular time, meaning it deviates from its original predecessor in having engines, appropriate emergency equipment, navigation- and radio aids and, since it's no longer a fishing schooner, she now has crew- and passenger accommodations. I assume the hull, her sail plan and most of the rigging still resembles the original Bluenose.Question, how closely does the Bluenose II follow the original bluenose design and build?
Please mind Jenson's note, stating the colors mentioned are but one of various possibilities, this one only being valid around 1931.
Of course you can start on assembling parts of the deck furniture, like the companion ways, the aft cabin, hatches. You could also extend that to the masts, gaffs and booms, as long as you don't install them. First priority for now is to get the hull as good as you can get it, including the finish you want to apply.Very informative, thank you.
Finish hull planking proceeding. Once that is completed, sanding and a little filling. Then I will have to decide on colors.
Can you start construction of the deck furniture before you complete the hull planking and painting? Any drawbacks to doing that?
That's a result worth aiming for!OK, Thank You.
This is the finish planking I am hoping to obtain in a few days. I have been using this photo as a reference.
Go for a primer.Do you think a primer coat would be recommended (gray/white)?
Unfamiliar with this product.Is this the recommended sander sealer for wood hulls
Kurt, this would be my approach:As the final hull planking progresses, I would like to know what others think of the laying of the planking. Any suggestions/ ideas for going forward?
I am using Tite bond III wood glue after wetting and bending planks into shape on the hull.
Thanks in advance.
