Scarfed the oak beams, glued them and then just drilled three 1mm holes and pushed a square 1mm mahogany strip through. Looks nice as a trenail? Hardly seen but fun to do.
Many thanks Uwek.When you have quiet hour and you are patient, I would use a pair of good twicers and some very small drops of super glue
The light green one (thick) from Tidebond needs appr. 1 minute to dry ....enough time to correct if necessary
Good morning. Wow, this is beautiful. Cheers GrantThis bit is so vague in the instructions but came out ok .
Hi. I didnt use Occre satin but just a rattle can satin varnish on most of the ship. Came out ok i think.Very nice work and the Victory looks fantastic.
Did you use Occre Satin Varnish? It looks that way on the decks.
