Some of the brass parts that I cut from the sheet needed to be lightly sanded to remove the coating that was preventing the brass-black from taking. That included the stanchions which I eventually discarded in favour of more substantial ones I bought elsewhere.But for some reason the brass black didn't take on the ladder pieces even after washing them in denatured alcohol. I guess I'll have to paint them. I was hoping to use the gun metal blackening and brass blackening on as much as I could.
Thanks, Barcomad. And where did you get your stanchions from?Some of the brass parts that I cut from the sheet needed to be lightly sanded to remove the coating that was preventing the brass-black from taking. That included the stanchions which I eventually discarded in favour of more substantial ones I bought elsewhere.
Perhaps use a corner of the brass sheet to try it out and see how much (or little) sanding it needs.
Hope this helps.
I don't remember the name of the company from where I actually sourced them but it was in Holland, originally from Billing Boats.Thanks, Barcomad. And where did you get your stanchions from?
"Betún" is Spanish for "Bitumen"Love this hack! Since the brass black didn't take, I'm just going to paint them. Probably spray paint them black when I paint the hull. I assume the ladders on the actual ship were wooden, so not sure if black is a good idea. I can always take a trip to the hardware store and get some brown spray paint and paint them brown if the black doesn't look good.
Everything else that I blackened or blued came out nice. Sanded it in a jar full of sand, just swished the parts around for a bit.
And started painting the stanchions and small stacks white. I'm not crazy about how the pueter parts come out when painted white. For my Endurance, I'm going for a look of what the ship might have looked like in it's last days before the ice broke it up. So I thought of mixing a little black with the last coat of white to give them a dingier look. Any thoughts?
Then I started looking ahead in the instructions. The last page shows OcCre seemingly painting the hull and deck furniture with Betun du Judea. I've never used this. What is it? Is it like Tung Oil? What would it do to my painted surfaces? Would it dull the white to make it look more realistic? And is it the same thing as bitumen of Judea?
Lacquer? Polyurethane?Try a matte clear coat to knock the shine down if needed.
Do a test piece as you may get a chemical reaction if using different sprays.
Testers clear has a fantastic reputation in the model world. Dries very quickly and seals. I used it when painting resin statue kits. Faultless.Lacquer? Polyurethane?
Probably right. I always used it with acrylic paints.I may be wrong, but shouldn't the clear coat be the same variety as the paint? Lacquer on lacquer or acrylic on acrylic.
