Hohenzollernmodell 1660-1670 Scale 1/75 POF build by Stephan Kertész (Steef66)
Thanks all for the likes, comments and Visit.
The floor timbers are in shape and I also constructed the Kolzem, in English Keelson. Luckily the Keelson is almost straight, only a light bend on the bow- and stern section. Only a precise and strong clamping in that area was necessary to get it in place. The thickness of the keelson is 5 mm. and a width of 12 mm. Not easy to bend, but in this case a "makkie" (Dutch for a easy job)
Only them clamping was a little more.... How too?
I got a Idea with my Proxxon MF70. The z-axle is with a screw and pretty strong. So I used this to do the job.
Yes it looks dangerous to do it this way, but surprisingly enough the construction of keel, planks and floor timber is very strong. I used a hammer and chisel to shape the floor timbers, that also went very well. After a long time of drying (the glue need to harden before I get the ship out of the construction) I nailed the keelson to the floor timber with brass nails. Next thing on my list is a few layers of hull planks and a lot of study how to go further with the floor.
thanks for watching
View attachment 444776View attachment 444777View attachment 444778View attachment 444779View attachment 444780
thanks for watching
With only 2 hands your have to be inventive to install such a long piece of wood, Stephan. And the nails will hold the keelson in place.
Fantastic Stephan! Among the most interesting builds on the forum!
Thanks Paul, it's also fun to do. Because you have to think about every step you take.
Very good progress - Looking very good
Thanks Uwe.
Always searching to how it can be done with the stuf on your workplace take a hugh amount of time.
Good afternoon Stephan. I will have a break, watch the Expance and fix up the Bounty model in my pub. Then a POF British ship. Cheers Grant
The expance is great watching, not boring at all.
Your keelson work is superb, Stephan, but I do wonder why not steam-bend the timber before fixing in place?
Thanks, the keelson is almost straight, just a small bent. I just had to keep it in place to let the glue dry. That's why I clamped it and the machine was the perfect tool for this. I could use instead also a heavy weight, but the risk of movement was to high. The little mill is more steady.
Small update, but it was a time consuming work. I was attaching the planks on the kim till I reach the place where the first wale will come.
Then I can go further on the inside. A lot of measuring and bending is needed to end just under the wale.
Pictures of the clamping and my work spot.
View attachment 445897View attachment 445898View attachment 445899View attachment 445900
After a lot of work on the floor timber and keelson, it’s nice to work on the planking again. And I see that the keelson is helpful with the clamping. Nice work, Stephan.
Thanks for the likes and visit to my build log.
I had a lot to do, even some re-do's on the planking. There is 1 row to go before I reach the spot where the wale will come. I stop a while planking on the outside and go further with the inside. First the zitters, then the wegering and after that I start to make the shape of the ship with a few frames and attaching the centen. But I'm think this will be somewhere about Christmas.
After the planking was done I need to look for mistakes and gaps on the outside. Hide them by placing tiny pieces of wood inside them or replace parts of the planking. I made some pictures of that proces and the end result.
and a few other places
on side is done now the other side, but first a few pictures how it looks now.
Thanks for stepping by :)
View attachment 447710View attachment 447712View attachment 447713View attachment 447718View attachment 447720View attachment 447721View attachment 447723
View attachment 447714View attachment 447716
View attachment 447725View attachment 447726View attachment 447728View attachment 447729View attachment 447730
Nice re-do’s, Stephan. And her lines are very nice. The last picture shows that very well.
Thanks Peter, it is a lot of fun to see actually a ship form growing. Gives me indeed more pleasure in this build.
WOW, mon ami! She is taking shape, and now I can definitely see you building the Hohenzollern. As Peter said in the above post, the beautiful lines are the proof!
Thanks Jim, yes the shape of a Dutchman is recognizable.
Great results Stephan, very nice line.
Thanks Tobias.
That's some fancy repairs you had to make!
One might argue the repairs have authenticity, since Dutch shipwrights used any available shape and form to get the job done.
